[GRASS-dev] Transifex workflow - was: Re: [GRASS-SVN] r71617 - grass/trunk/locale/po
Hi Luca,
On Nov 1, 2017 10:34 AM, “Maris Nartiss” <maris.gis@gmail.com> wrote:
According to documentation, no:
https://grass.osgeo.org/development/translations/
https://grasswiki.osgeo.org/wiki/GRASS_messages_translation#Continuing_an_existing_translation
Is that outdated or not? I’m still not fully sure to have understood the workflow.
If Transifex is the only option, then I’ll research how to make lv
exempt of it (I assume modification of merge script will be enough).
I guess more is needed since updates from transifex are done in bulk.
Māris.
2017-10-31 20:48 GMT+02:00 Markus Neteler <neteler@osgeo.org>:
shouldn’t a translation update be done in transifex?
And from there uploaded to svn?
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
On 1 November 2017 at 11:20, Markus Neteler <neteler@osgeo.org> wrote:
Hi Luca,
Hi Markus,
Is that outdated or not? I'm still not fully sure to have understood the
workflow.
probably yes
If Transifex is the only option, then I'll research how to make lv
I guess Transifex should be the only option, but maybe msgmerge is
able to merge in both the direction, we should try, Maris could you
check after the next Transifex update if lv translation contain your
translated messages?
I think the only problem is in the Transifex translation that is not
able to get the translated messages from po file.
ciao
Luca
www.lucadelu.org
