File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/wxgui.py",
line 34, in <module>
from lmgr.frame import GMFrame
File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/lmgr/frame.py",
line 43, in <module>
from lmgr.layertree import LayerTree, LMIcons
File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/lmgr/layertree.py",
line 35, in <module>
from mapdisp.frame import MapFrame
File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/mapdisp/frame.py",
line 38, in <module>
from vdigit.toolbars import VDigitToolbar
File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/vdigit/toolbars.py",
line 24, in <module>
from iclass.digit import IClassIVDigit
File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/iclass/digit.py",
line 22, in <module>
from vdigit.wxdigit import IVDigit
File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/vdigit/wxdigit.py",
line 33, in <module>
from vdigit.wxdisplay import DisplayDriver, GetLastError
File "/home/metz/src/grass-7.0.svn/dist.x86_64-unknown-linux-gnu/etc/gui/wxpython/vdigit/wxdisplay.py",
line 70, in <module>
errtype = CFUNCTYPE(UNCHECKED(c_int), String, c_int)
NameError: name 'CFUNCTYPE' is not defined
On Fri, Dec 23, 2011 at 11:40 AM, Markus Metz
<markus.metz.giswork@googlemail.com> wrote:
in trunk r49877 the GUI fails with
My bad. I disabled the transform library in my local copy which caused
an import error which in turn was not captured. Re-enabling the
transform lib helped. BTW, I had to revert the GUI to r49809 to get a
meaningful error message. And the transform lib should probably be
removed altogether from trunk because the imagery lib does a better
job at transforming coordinates.
Markus M
