[GRASS-dev] trunk pb: "ImportError: No module named catalog"
this is what is displayed once I enter GRASS (trunk version), any idea what is (not) happening with catalog?
ISIS-GRASS 7.1.svn (Moon2000):~/dev > Traceback (most recent call last):
   File "/usr/local/grass-7.1.svn/gui/wxpython/wxgui.py", line 140, in <module>
     sys.exit(main())
   File "/usr/local/grass-7.1.svn/gui/wxpython/wxgui.py", line 132, in main
     app = GMApp(workspaceFile)
   File "/usr/local/grass-7.1.svn/gui/wxpython/wxgui.py", line 46, in __init__
     wx.App.__init__(self, False)
   File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk2/wx/_core.py", line 8628, in __init__
     self._BootstrapApp()
   File "/usr/lib/python2.7/dist-packages/wx-3.0-gtk2/wx/_core.py", line 8196, in _BootstrapApp
     return _core_.PyApp__BootstrapApp(*args, **kwargs)
   File "/usr/local/grass-7.1.svn/gui/wxpython/wxgui.py", line 79, in OnInit
     from lmgr.frame import GMFrame
   File "/usr/local/grass-7.1.svn/gui/wxpython/lmgr/frame.py", line 73, in <module>
     from datacatalog.catalog import DataCatalog
Mobile: +33 (0)7 83 85 52 34
please try to recompile GRASS from scratch
make distclean
svn up
configure
Ma
2015-09-24 7:43 GMT+02:00 Yann <ychemin@gmail.com>:
<module>
    sys.exit(main())
__init__
8628, in __init__
<module>
grass-dev mailing list
grass-dev@lists.osgeo.org
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
This is the same problem I had earlier. There is some reference in your installed directory that it doesn't like. After you recompile, remove your existing installation before installing your compiled version.
On 2015-09-24 03:32 AM, Martin Landa wrote:
make distclean
svn up
configure
Ma
<module>
     sys.exit(main())
__init__
8628, in __init__
<module>
