on the Debian build server the following problem appeared in trunk
(relbranch is fine):
make sphinxdoclib
SPHINXBUILD: Found <sphinx-build>
SPHINXAPIDOC: Found <sphinx-apidoc>
SPHINXBUILD: Using <sphinx-build>
GISRC=/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/demolocation/.grassrc71
GISBASE=/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu
PATH="/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/bin:/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/bin:/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/scripts:$PATH"
PYTHONPATH="/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/etc/python:/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/gui/wxpython:$PYTHONPATH"
LD_LIBRARY_PATH="/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/bin:/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/bin:/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/scripts:/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/lib:/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/lib:"
LC_ALL=C sphinx-build -b html -d _build/doctrees -c . src/
/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/docs/html/libpython
Running Sphinx v1.2.3
Exception occurred:
File "/usr/lib/python2.7/subprocess.py", line 1335, in _execute_child
raise child_exception
OSError: [Errno 2] No such file or directory
The full traceback has been saved in /tmp/sphinx-err-S54551.log, if
you want to report the issue to the developers.
Please also report this if it was a user error, so that a better error
message can be provided next time.
A bug report can be filed in the tracker at
<https://bitbucket.org/birkenfeld/sphinx/issues/>\. Thanks!
Makefile:71: recipe for target 'libpythonhtml' failed
make[1]: *** [libpythonhtml] Error 1
make[1]: Leaving directory
'/home/neteler/grass7_svn_head_bin_snapshot/trunk/lib/python/docs'
include/Make/Sphinx.make:47: recipe for target 'sphinxdoclib' failed
make: *** [sphinxdoclib] Error 2
neteler@osgeo6:~/grass7_svn_head_bin_snapshot/trunk$ cat
# Sphinx version: 1.2.3
# Python version: 2.7.9
# Docutils version: 0.12 release
# Jinja2 version: 2.7.3
# Loaded extensions:
File "/usr/lib/python2.7/dist-packages/sphinx/cmdline.py", line 253, in main
warningiserror, tags, verbosity, parallel)
File "/usr/lib/python2.7/dist-packages/sphinx/application.py", line
107, in __init__
confoverrides or {}, self.tags)
File "/usr/lib/python2.7/dist-packages/sphinx/config.py", line 229,
in __init__
execfile_(filename, config)
File "/usr/lib/python2.7/dist-packages/sphinx/util/pycompat.py",
line 105, in execfile_
exec code in _globals
File "conf.py", line 45, in <module>
grass_version = core.version()['version']
File "/home/neteler/grass7_svn_head_bin_snapshot/trunk/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py",
line 1518, in version
data = parse_command('g.version', flags='rge', errors='ignore')
line 501, in parse_command
res = read_command(*args, **kwargs)
line 458, in read_command
process = pipe_command(*args, **kwargs)
line 433, in pipe_command
return start_command(*args, **kwargs)
line 377, in start_command
return Popen(args, **popts)
line 74, in __init__
subprocess.Popen.__init__(self, args, **kwargs)
File "/usr/lib/python2.7/subprocess.py", line 710, in __init__
errread, errwrite)
neteler@osgeo6:~/grass7_svn_head_bin_snapshot/trunk$ sphinx-
sphinx-apidoc sphinx-autogen sphinx-build sphinx-quickstart
neteler@osgeo6:~/grass7_svn_head_bin_snapshot/trunk$ sphinx-apidoc --version
Sphinx (sphinx-apidoc) 1.2.3
Any ideas? Recently it worked.
