[GRASS-dev] two-resolution support
  Currently, r.resamp.stats operates at two different resolutions
  -- the one obtained from the current region (the resolution of
  the destination raster) and the one obtained from the raster the
  module operates on (the source resolution.)
  Does it sound sensible to generalize the concept and allow for
  arbitrary region to be specified for the source resolution (so
  that the source raster is effectively downsampled prior to
  applying the aggregation function)? May it make sense to add
  explicit support for the secondary region at libgis level?
