Apparently, for unprojected reference systems, r.proj doesn’t accept the parameter resolution expressed in DD:MM:SS, but only in decimal degrees (at least for me, any other experience?), while for example g.region does accept this format. The type of the parameter resolution is float for r.proj and integer for g.region (as far as i can understand digging into the source code). My (probably naive) question is : Wouldn’t it make sense to adopt integer type also for r.proj?
Thanks for any pointers
Best regards,
Dr. Margherita DI LEO
Scientific / technical project officer
European Commission - DG JRC
Institute for Environment and Sustainability (IES)
Via Fermi, 2749
I-21027 Ispra (VA) - Italy - TP 261
Tel. +39 0332 78 3600
margherita.di-leo@jrc.ec.europa.eu
Disclaimer: The views expressed are purely those of the writer and may not in any circumstance be regarded as stating an official position of the European Commission.
