Minor bit of feedback to the developers: I think "constains" should
be "contains" in the following message from r.out.gdal (using version
6.3 of GRASS):
WARNING: Input raster map constains cells with NULL-value (no-data). The
value -1 was used to represent no-data values in the input map.You
can specify nodata value by nodata parameter.
Also, there's no space between the two sentences.
Bruce
Bruce Raup
http://cires.colorado.edu/~braup/
6.3 of GRASS):
Thanks, Bruce, fixed in SVN.
It more recent versions (>= 6.4) it was already corrected.
