Hello wxGUI'ers,
as I took my first step in wxGUI/wxPython land, I was wondering - is
there some user interface designer that could be used for wxGUI?
There seems to be no XML UI files in gui_modules dir. Is there some
designer, that allows to work with code directly?
Maris.
PS. Martin - if r42597 seems OK, it should go to 6.5/6.4 as per #651.
currently no designer (and probably it will not changed) is used for
developing wxGUI. Designers for wxPython are not so much advanced and
usable compared e.g. to QtDesigner.
