[GRASS-dev] Unable to find grass7 start script after svn update/recompile
Hello,
i have a problem starting grass7 from the "dist" directory.
I recently made an svn update and recompiled grass7 from scratch.
Now the grass7 start script is missing in the "dist" directory.
What can i do.
I would like to avoid a make install to test my code changes?
Best regards
Soeren
2010/4/6 Soeren Gebbert <soerengebbert@googlemail.com>:
you can find start script in "bin" directory (`grass70`).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Hello Martin,
2010/4/6 Martin Landa <landa.martin@gmail.com>:
Unfortunately not:
grass_trunk> find dist.i686-pc-linux-gnu/ -name \*grass70\*
grass_trunk>
It looks to me that the start script is not generated in the dist directory.
Soeren
Martin
Unfortunately not:
grass_trunk>
find bin.i686-pc-linux-gnu/ -name \*grass70\*
start script (pythonized) has been moved from `dist` to `bin` directory.
Martin
Hi Martin,
Unfortunately not:
grass_trunk>
Ok, got it ... i am slow to catch on. :wink:
Thanks Martin.
Soeren
Martin
