[GRASS-dev] unable to install my grass module from the GitHub repository
Hi all!
I’m trying to install my module i.sentinel.mask from the GitHub repository [0] using g.extension but I get the following error:
g.extension extension=i.sentinel.mask operation=add url=https://github.com/RobiFag/GRASS_clouds_and_shadows
Fetching <i.sentinel.mask> from <https://github.com/RobiFag/GRASS_clouds_and_shadows/archive/master.zip> (be patient)…
Compiling…
Installing…
make: *** No rule to make target `install’. Stop.
WARNING: Installation failed, sorry. Please check above error messages.
any suggestion?
Thanks in advance!
Roberta
[0] https://github.com/RobiFag/GRASS_clouds_and_shadows
Am 5. Juni 2018 14:38:49 MESZ schrieb Roberta Fagandini <robifagandini@gmail.com>:
Hi all!
I'm trying to install my module i.sentinel.mask from the GitHub
repository
I think you have to point it to the directory of your add-on, i.e.
https://github.com/RobiFag/GRASS_clouds_and_shadows/i.sentinel.mask
But am in a train and can't test right now.
Moritz
Hi Roberta,
On Tue, Jun 5, 2018 at 2:38 PM, Roberta Fagandini <robifagandini@gmail.com> wrote:
Hi all!
Compiling…
Installing…
any suggestion?
One error was
Compiling…
make[1]: *** No rule to make target /tmp/grass7-roberta-701 4/tmpe7QEso/i.sentinel.mask/scripts/i.sentinel.mask', needed by script’. Stop.
/bin/sh: 1: cannot create /usr/lib/grass74/error.log:
Permission denied
i.e. this is a system-wide installation of GRASS 7.4
Can you try again with GRASS 7.5 compiled from source, without installing? That should avoid the “Permission denied” error.
The GRASS start script is in the source tree in bin.x86_64-pc-linux-gnu
Markus M
Thanks in advance!
Roberta
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Hi Markus!
2018-06-05 14:49 GMT+02:00 Markus Metz <markus.metz.giswork@gmail.com>:
Hi Roberta,
Hi all!
Compiling…
Installing…
any suggestion?
One error was
Compiling…
Permission denied
I tried with GRASS 7.5 and I got the error message
Compiling…
Installing…
While if I point it to the directory of the add-on (https://github.com/RobiFag/GRASS_clouds_and_shadows/i.sentinel.mask) I get another error:
Fetching <i.sentinel.mask> from <https://github.com/RobiFag/GRASS_clouds_and_shadows/i.sentinel.mask/archive/master.zip> (be patient)…
ERROR: Extension <i.sentinel.mask> not found
Roberta
Markus M
Thanks in advance!
Roberta
On Tue, Jun 5, 2018 at 8:49 AM, Moritz Lennert <mlennert@club.worldonline.be
>Hi all!
>repository
Unfortunately, g.extension GitHub/GitLab/... repository downloads currently
support only module (Makefile to be exact) at the top level. You need to
download the repo (e.g. a snapshot in the ZIP file) and point g.extension
to the right (sub)directory (with Makefile) or just add couple of functions
to g.extension to find that directory.
Vaclav
Thank you, Vaclav!
I moved the module at the top level and now it works!!
Roberta
2018-06-05 15:31 GMT+02:00 Vaclav Petras <wenzeslaus@gmail.com>:
On Tue, Jun 5, 2018 at 8:49 AM, Moritz Lennert <mlennert@club.worldonline.be> wrote:
Hi all!
repository
But am in a train and can’t test right now.
Unfortunately, g.extension GitHub/GitLab/… repository downloads currently support only module (Makefile to be exact) at the top level. You need to download the repo (e.g. a snapshot in the ZIP file) and point g.extension to the right (sub)directory (with Makefile) or just add couple of functions to g.extension to find that directory.
Vaclav
