I’ve been compiling the geoPAT extensions for GRASS from http://sil.uc.edu/gitlist/geoPAT/
At the time I was running GRASS 7.2.2 installed from the Ubuntu GIS repository, but since this repo updated to GRASS 7.4, I have the following issue:
GRASS 7.4.0 (modis_lst_2015):~ > p.sig.polygons --help
ERROR: Module built against version $Revision: 70617 $ but trying to use
version $Revision: 70829 $. You need to rebuild GRASS GIS or
untangle multiple installations.
[Raster MASK present]
Any pointers about how to resolve the version tangling? I’ve tried recompiling geoPAT, but that didn’t work.
Pierre
Howdy Pierre!
In my experience, the GeoPat modules need to know where several things
are located, including (I think) parts of the GRASS source code. Have
a look through the install.sh code:
http://sil.uc.edu/gitlist/geoPAT/blob/stable/install.sh
I was able to get these modules up and running by invoking install.sh like this:
sh install.sh grass75
... where "grass75" is the binary compiled from grass_trunk. The
install.sh code seemed to find the source code it needed and worked
without issue.
How did you install / upgrade the Geopat modules? Could it be that
install.sh is "finding" the old source code / headers? Is there a
package for both GRASS binaries and development files?
Dylan
On Thu, Feb 22, 2018 at 7:28 PM, Pierre Roudier
<pierre.roudier@gmail.com> wrote:
I've been compiling the geoPAT extensions for GRASS from
issue:
Any pointers about how to resolve the version tangling? I've tried
recompiling geoPAT, but that didn't work.
Pierre
grass-dev mailing list
grass-dev@lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/grass-dev
Thanks Dylan,
I did install using sudo sh install.sh grass72
– then sudo sh install.sh grass74
after my Grass version got updated to 7.4
P
On 23 February 2018 at 18:41, Dylan Beaudette <dylan.beaudette@gmail.com> wrote:
Howdy Pierre!
… where “grass75” is the binary compiled from grass_trunk. The
without issue.
install.sh is “finding” the old source code / headers? Is there a
Dylan
issue:
Pierre
How about your GRASS "development" files: installed via package
manager? Same version as the binaries?
D
On Fri, Feb 23, 2018 at 1:10 PM, Pierre Roudier
Thanks Dylan,
I did install using `sudo sh install.sh grass72` -- then `sudo sh install.sh
grass74` after my Grass version got updated to 7.4
P
wrote:
Howdy Pierre!
this:
without issue.
Dylan
> Hi,
> following
> issue:
> Cheers,
> Pierre
Dear all,
this may not address this specific problem with multiple installations, but it may help overall with debugging such problems because it is more direct. I’m attaching a geoPAT patch which deals with the names of the libraries and removes the need to modify GRASS source code before the compilation happens.
The following command executed in the directory with the source code should be sufficient to compile modules with a self-compiled GRASS which is not in system:
make MODULE_TOPDIR=~/…/trunk/ GRASS_VERSION_NUMBER=7.5.svn
Path to the GRASS GIS installation/code/dev files and the version needs to be provided. This was tested with the current trunk in a home directory and not with GRASS installed (make install
-ed) in the system. Nevertheless this removes the need to modify the source code and thus increasing compatibility with different GRASS versions (which change the copied and modified file).
Besides the limited testing, there are three other issues:
g.extension is not able to install the code from a directory (or ZIP, …) because no system for C addon modules with libraries is in place (same issue as with r.pi.* suite). When GRASS_VERSION_NUMBER is added to g.extension code and HTML for the main directory is resolved/or ignored in g.extension, modules at least compile, but nothing is installed (added) to the local addons directory.
I don’t understand why GRASS_VERSION_NUMBER isn’t already defined.
I don’t know how to contribute to the geoPAT repository.
Best,
Vaclav
(attachments)
geoPAT-include-in-makefiles.diff (4 KB)
On Fri, Feb 23, 2018 at 6:22 PM, Dylan Beaudette <dylan.beaudette@gmail.com> wrote:
How about your GRASS “development” files: installed via package
D
Thanks Dylan,
P
wrote:
Howdy Pierre!
this:
without issue.
Dylan
following
issue:
Pierre
Hey Dylan,
Yes, these were installed using the grass-dev package in the UnbuntuGIS repo,
P
On 24 February 2018 at 12:22, Dylan Beaudette <dylan.beaudette@gmail.com> wrote:
D
Thanks Dylan,
P
wrote:
Howdy Pierre!
this:
without issue.
Dylan
following
issue:
Pierre
Hi Vaclav, and thank you so much for your help,
Do I understand correctly that I should compile a version of GRASS to use your patch?
P
On 25 February 2018 at 15:52, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Dear all,
Best,
Vaclav
D
Thanks Dylan,
P
wrote:
Howdy Pierre!
this:
without issue.
Dylan
following
issue:
Pierre
On Sun, Feb 25, 2018 at 10:41 PM, Pierre Roudier <pierre.roudier@gmail.com>
You are welcome.
your patch?
The patch is for geoPAT, but I tested the subsequent compilation of geoPAT
only against compiled GRASS (which is not `make install`ed).
P
Dear all,
direct. I'm attaching a geoPAT patch which deals with the names of the
not in system:
make MODULE_TOPDIR=~/.../trunk/ GRASS_VERSION_NUMBER=7.5.svn
and not with GRASS installed (`make install`-ed) in the system.
1) g.extension is not able to install the code from a directory (or ZIP,
...) because no system for C addon modules with libraries is in place (same
2) I don't understand why GRASS_VERSION_NUMBER isn't already defined.
3) I don't know how to contribute to the geoPAT repository.
Best,
Vaclav
D
> Thanks Dylan,
install.sh
> Cheers,
> P
> wrote:
>> Howdy Pierre!
like
>> this:
>> without issue.
>> Dylan
>> > Hi,
>> > following
>> > issue:
to use
>> > Cheers,
>> > Pierre
>> > _______________________________________________
Dear Vaclav,
Here’s what I ended up doing:
I updated my GRASS trunk and compiled (./configure, make, then make install)
I applied your patch to geoPAT
I ran make MODULE_TOPDIR=/usr/local/src/grass7_trunk/ in the geoPAT directory
Unfortunately still the same issue running it in grass75:
GRASS 7.5.svn (modis_lst_2015):/usr/local/src/grass7_trunk > p.sig.grid --help
version $Revision: 72230 $. You need to rebuild GRASS GIS or
Any idea what I might have missed?
Pierre
On 26 February 2018 at 16:53, Vaclav Petras <wenzeslaus@gmail.com> wrote:
On Sun, Feb 25, 2018 at 10:41 PM, Pierre Roudier <pierre.roudier@gmail.com> wrote:
You are welcome.
The patch is for geoPAT, but I tested the subsequent compilation of geoPAT only against compiled GRASS (which is not make install
ed).
P
Dear all,
Best,
Vaclav
D
Thanks Dylan,
P
wrote:
Howdy Pierre!
this:
without issue.
Dylan
following
issue:
Pierre
On Mon, Feb 26, 2018 at 4:51 PM, Pierre Roudier <pierre.roudier@gmail.com>
wrote:
* I ran make MODULE_TOPDIR=/usr/local/src/grass7_trunk/ in the geoPAT
directory
--help
Sorry, I suspected that will be the case, perhaps I was not clear enough
about that. I think you need to 1) look at the compilation output from make
specifically the compiler commands which are executed and the libraries
linked there, 2) do `make MODULE_TOPDIR=/usr/local/src/grass7_trunk/ clean`
and delete all p.si* files in /usr/local/... including the library (.so and
.so.*) before you run the actual make, and 3) probably run
`make MODULE_TOPDIR=/usr/local/src/grass7_trunk/ install` with `sudo` as
well since you have the code in the system (but I don't do this, so I don't
have procedure in my head).
