hi devs,
see
http://osgeo-org.1560.x6.nabble.com/WinGRASS-build-up-WIP-tp5420766p5421066.html
upcoming winGRASS 7.8.1 will be out with gdal3 and proj6:
GRASS is now configured for: x86_64-w64-mingw32
Source directory: /usr/src/rc_nexgen/grass-7.8.1RC1
Build directory: /usr/src/rc_nexgen/grass-7.8.1RC1
Installation directory: ${prefix}/grass78
Startup script in directory:/c/OSGeo4W64/bin
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
Building shared libraries: yes
OpenGL platform: Windows
MacOSX application: no
MacOSX architectures:
MacOSX SDK:
BLAS support: no
BZIP2 support: yes
C++ support: yes
Cairo support: yes
DWG support: no
FFTW support: yes
FreeType support: yes
GDAL support: yes
GEOS support: yes
LAPACK support: no
Large File support (LFS): yes
libLAS support: yes
MySQL support: no
NetCDF support: no
NLS support: yes
ODBC support: yes
OGR support: yes
OpenCL support: no
OpenGL support: yes
OpenMP support: no
PDAL support: no
PNG support: yes
POSIX thread support: no
PostgreSQL support: yes
Readline support: no
Regex support: yes
SQLite support: yes
TIFF support: yes
X11 support: no
Zstandard support: yes
using new PROJ 5+ API <=
GRASS GIS 7.8.1RC1 exported compilation log
Started compilation: Tue Nov 5 22:20:43 CET 2019
Errors in:
No errors detected.
Finished compilation: Tue Nov 5 23:04:48 CET 2019
System Info
GRASS Version: 7.8.1RC1
Code revision: exported
Build date: 2019-11-05
Build platform: x86_64-w64-mingw32
GDAL: 3.0.2 <=
PROJ: 6.2.1 <=
GEOS: 3.8.0
SQLite: 3.29.0
Python: 3.7.0
wxPython: 4.0.3
Platform: Windows-10-10.0.18362-SP0 (OSGeo4W)
great work!
please test in the OSGeo4W framework with the Exp. tick activated.
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
