[GRASS-dev] Updated OGR/SHAPELIB based DBF driver crashing with GRASS SVN
Frank,
after syncing (as regularly) the DBF driver from SHAPELIB embedded
in OGR, we face the problem that it no longer works with older GDAL
versions than current SVN:
http://trac.osgeo.org/grass/ticket/110
I don't know what to do. In essence, I don't want to fork our version
from yours.
Any ideas?
thanks
On Wed, Apr 9, 2008 at 11:31 AM, Maris Nartiss <maris.gis@gmail.com> wrote:
It's known as issue 110 [1].
Maris.
1. http://trac.osgeo.org/grass/ticket/110
2008/4/9, benjamin.ducke@ufg.uni-kiel.de <benjamin.ducke@ufg.uni-kiel.de>:
> FWIW, the DBF driver still does not seem to be usable.
> On Ubuntu 7.10, GDAL 1.5.1, with a version compiled from SVN (did make
> distclean), I cannot access attribute data stored in a DBF file.
> v.info -c simply results in a segfault.
> GRASS 6.3.RC6 works fine on the same system and with the same GDAL.
> Best,
> Benjamin
> grass-dev mailing list
> grass-dev@lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
from yours.
Any ideas?
I suggest using a "stub" implementation of the I/O hooks. E.g.:
typedef struct {
    FILE* (*FOpen) ( const char *filename, const char *path);
    size_t (*FRead) ( void *p, size_t size, size_t nmemb, FILE* file);
    size_t (*FWrite)( void *p, size_t size, size_t nmemb, FILE* file);
    long (*FSeek) ( FILE* file, long offset, int whence );
    long (*FTell) ( FILE* file );
    int (*FFlush)( FILE* file );
    int (*FClose)( FILE* file );
    void (*Error) ( const char *message );
} SAHooks;
static void error_fn( const char *message )
    G_fatal_error("%s", message);
static void SASetupDefaultHooks( SAHooks *psHooks )
    psHooks->FOpen = fopen;
    psHooks->FRead = fread;
    psHooks->FWrite = fwrite;
    psHooks->FSeek = fseek;
    psHooks->FTell = ftell;
    psHooks->FFlush = fflush;
    psHooks->FClose = fclose;
    psHooks->Error = error_fn;
from yours.
Any ideas?
typedef struct {
} SAHooks;
Folks,
I'm just trying to catch up on this topic. There is already a stdio
based implementation in shapelib itself. I have attached it,and it is
normally in a file called safileio.c.
I'm afraid I'm uncertain of the implications of mixing the Shapelib 1.3
code with GDAL's using Shapelib 1.2. It seems potentially like it could
be a problem.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam, warmerdam@pobox.com
light and sound - activate the windows | http://pobox.com/~warmerdam
and watch the world go round - Rush | President OSGeo, http://osgeo.org
(attachments)
safileio.c (9.45 KB)
Frank,
be a problem.
This is unclear to me since I took the code from GDAL itself.
