[GRASS-dev] Updated WinGrass release installer now available
dumb question:
is it possible for the grass 6.4.0 native grass installer for MS-Windows
to ship with both Tcl/Tk gis.m and the wxPython GUI?
.... i.e. give the user a choice & a backup plan ...
Hamish
This installer does ship with both. Although I thought there were
enough desktop icons already (with and without msys), in the start
menu there is an "Old GUI" option that will start a fully functional
tcltk with nviz. Or if you want to still use msys, just open the msys
desktop icon and change the argument from
"/grass/bin/grass64 -wxpython"
to
"/grass/bin/grass64 -tcltk"
Question for those who are testing: do you prefer the msys version
(with a functioning terminal) or the other one (which runs
grass64.bat)? Both is probably confusing, but I don't want to remove
the older grass64.bat option without consultation from those who
created it on their specific reasons for it.
-Colin
On Thu, Apr 9, 2009 at 4:21 AM, Hamish <hamish_b@yahoo.com> wrote:
dumb question:
Hamish
grass-dev mailing list
grass-dev@lists.osgeo.org
The reason for it is so GRASS can be started on Windows without having to install Msys. Msys is only needed for a few scripts - with GRASS 7 where all the scripts have been converted to Python there should be no need for Msys at all. Helena's argument about it being helpful to have a mini-Unix environment with familiar Unix commands is very valid though. But for testing/development purposes I think it's best to leave the Msys commands out of the PATH as having them installed can hide Unix-isms in GRASS - there was quite a bit of work went into removing these a couple of years ago and making GRASS truly native on Windows without the need for Msys.
Hope that clarifies things a bit?
Paul
just a note that the msys version is used a lot in my class although I haven't
really included it into assignments - I just let the students know that it exists and what
they can do with and it quickly gets used a lot for automating workflows.
And it has the advantage of introducing people to linux.
I don't have a problem at all with having both versions and two icons - it was clearly explained
on Marco's web page and did not cause too much confusion.
Helena
Paul
Yes that does clarify things and I figured there probably had been a
good reason for converting to a .bat file.
So given that lots of people like msys for various reasons, but that
we should make sure that is not required, is there a consensus as to
how should I set up the installer in terms of desktop and start menu
icons?
(As a side note when trying to use the GUI menu to switch the default
GUI I get the following error:
  File "c:/GIS/GRASS-6-SVN/etc/wxpython/wxgui.py", line 515,
in OnMenuCmd
menuform.GUI().ParseCommand(cmd, parentframe=self)
  File
"c:\GIS\GRASS-6-SVN\etc\wxpython\gui_modules\menuform.py",
line 1716, in ParseCommand
xml.sax.parseString( getInterfaceDescription(cmd[0]),
handler )
  File
line 1657, in getInterfaceDescription
raise IOError, _("Unable to fetch interface description for
command '%s'.") % cmd
IOError
Unable to fetch interface description for command
'g.change.gui.py'.
-Colin
On Thu, Apr 9, 2009 at 9:17 AM, Paul Kelly
Paul
