I just uploaded a new version of gism.py and related files. I’ll keep an archive and so changed the link in the GRASS WIKI (development/python section) to go to the folder rather than the file itself so I won’t have to keep changing the link. This update includes the following changes:
*The biggest change in wrapping in grassgui.py. This provides autogenerated wxPython GUI dialogs for all grass commands.
This can now be called from the command console (just type in the command name with no arguments as you do now) or the
prototype menus. I updated grassgui.py to current wxPython syntax (mostly – event bindings need to change to new Bind method) and added methods to make it callable from other modules. I also added scroll bars. We need to add buttons (and relevant module or method like select.tcl) to browse GRASS ‘elements’ (i.e., rasters, vectors, files, etc.). Thanks very much to Yann Chemin for showing that grassgui.py worked.
*Methods added to gism.py and grassgui.py that automatically restart them with pythonw for the Mac.
*Change to subprocess module for running commands in the shell–seems to have stopped the double dialog boxes.
Important things to do. I’d like to start thinking about moving this to the cvs so that we can work on it collaboratively in a more controlled way. It should go into the grass6/gui/wxpython folder in the cvs. In the compiled binary, I’m guessing that it should end up in its own directory (e.g., wxp or gmwxp) like gm and dm. But I have a BIG PROBLEM. I can’t get gism.py to run from another directory, even though python is in my path and runs fine. That is, when in my home directory, if I try to run…
pythonw $GISBASE/etc/wxp/gism.py
…my Mac crashes with a bus error—even though $GISBASE has a value and even when I expand it to type out the full path. I’ve tried setting $PYTHONPATH (i.e., for module search path) and it makes no difference. I don’t know whether this is a Mac problem, something weird with my system, or something I don’t know about yet with Python. Anyone have any thoughts?
If this were fixed, we could easily make a script (e.g., gismpy) that could launch it from the GRASS command prompt.
I can’t yet get d.* commands to work from the new autodialogs, but they work from the command line. It’s a parameter passing issue. Other commands seem to work fine.
I think we’re ready to do the layer manager, layer options panels, and menu or toolbox.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
