[GRASS-dev] updates to grass startup
I just committed a set of patches to the GRASS startup tcltk files (gis_set.tcl, epsg_option.tcl, and file_option.tcl). These are designed to make creating a new location from EPSG code or georeferenced file more robust. This is especially important for Windows users who cannot make a new location with g.proj.
I’ve tested these on my Mac OSX with x11 GRASS cvs build of last Friday and they seem to be fine. Please test on other platforms.
Also, if we are going to have EPSG codes as a standard way to create a new location (and I think this is a handy way to go), can we distribute a copy of the EPSG file inside the GRASS directory structure (e.g., in the infamous catchall etc or another directory)? The EPSG file is ending up in different places on different architectures making it difficult to find. If it was always in the same place, within the GRASS hierarchy, it would be easy to make this the default location for the GUI.
Obviously the next thing to do is to make it searchable.
Michael
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
when creating a new location from EPSG code an xterm flashes up and then
disappears. This might have some important info/warning/error in it.
I have prepared the following patch, but not applied it as it makes the
script partially interactive. (ie it asks the user to press <enter> to
continue, but times out in 2 minutes [enough time to find a pen and
write down an error])
So not a great solution, but here it is.
Better? put a pause at end of exec grass-xterm-wrapper:
lib/init/epsg_option.tcl.in:
exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e \
         $env(GISBASE)/etc/make_location_epsg.sh \
         $epsg_code $epsgLocation $locpath >@stdout 2>@stderr; \
         read -t 120
or somehow like that?
Hamish
(attachments)
make_loc_pause.diff (2.01 KB)
I¹ve tested these on my Mac OSX with x11 GRASS cvs build of last
now locations and mapsets are not sorted in alphabetical order.
:confused:
not for, but not strongly against, however:
- The EPSG database and proj.4 are likely to be updated more often than
GRASS is.
- packagers should set --with-proj-share=, ./configure should give a
clear error message if not found for home-brew. Tcl then finds this dir
in the "PROJSHARE" variable.
yes please, and auto-fill the highlighted value in the create dialogue.
Hamish
my cleanup just fixed bugs 5328 and 5373. It also pariatly fixed 5372
and 5371 (My fault - too much bugs in one report).
Summarising up:
Currently there is no mechanism to catch error if creating of new
location has failed. Current code always will look like it has suceed
and will restart GRASS to strat use newly created location. Hamish
code will only make error message visible to user (good thing), but
GRASS should not continue as if everything was OK.
When creating new location from EPSG code, there is some error in
cleaning up temporary location in case of error. (See below)
Creating new location from georeferenced file still will not work, as
it needs some (temporary) location to run g.proj. Probably
make_location_epsg.sh.in could be used to create new, similar script
for georeferenced file too. Or probaby some new script, that creates
valid temporary location and then cleans up for any module, that may
need temporary location for running (do we need such script?).
To reproduce problems - 1) rm .grassrc6 (This why n00bs report
unreporoducable errors - daily grass users always have .grassrc6 with
valid locations/mapsets);
2) create new location with EPSG code 1234 - tmp location is left over;
3) repeat 1st step and now create new location from valid
georeferenced file - error.
Currently I'm not as good in coding to fix those problems :frowning:
Just trying to make GRASS fool proof,
Maris.
2006/12/13, Hamish <hamish_nospam@yahoo.com>:
         read -t 120
Hamish
Hello Michael
BTW that is no longer true. g.setproj and etc/set_data work fine on Windows (better if you have Msys in your path though - I'm working on replacing a system("ls -C") call). If you click the "projection values" button in gis_set.tcl it will pop up a Window running set_data so you can create a location the traditional way. Current problem though is that the list of locations doesn't refresh to show the new location after you return from the box. I had a quick look a week or two ago but the design of gis_set.tcl seemed to make it very difficult to refresh that. Although if you click after the database directory and press Enter it refreshes. Maybe you have improved something to make that easier though?
I¹ve tested these on my Mac OSX with x11 GRASS cvs build of last Friday and
I tried to create a location with EPSG code but it just says "WARNING: The epsg-codes file was not found!" and nothing appears to happen. Surely it isn't necessary to have that file installed if you already know the code you need? It isn't used for anything other than browsing and while including it in GRASS is definitely preferable to having to look for it wherever it was installed with PROJ, my preference would be to remove it altogether and instead in some way generate the lists from the .csv files in lib/proj that are actually used by g.proj to generate the location. Not sure how to do that but I think it's very confusing the way the file used for browsing is different from and potentially out of sync with the file used in the location generation.
Or another option would be to use the PROJ.4 definitions in that file directly and forget about the roundabout way it is currently done by passing the EPSG code to g.proj as part of a PROJ-style projection description? Whatever's done will probably need a bit of work though.
Paul
On Wed, 13 Dec 2006, Maris Nartiss wrote:
Summarising up:
I think we could maybe include the "demolocation" in the released distribution? It is small so not much overhead and contains a valid GISRC file that can be used in the initial stages.
Really important. The startup is IMHO one of the most awkward, antiquated and bugprone parts of GRASS which I'm sure really puts people off!
Paul
:confused:
I wonder what changed this? Need to look back at the code. Maris?
GRASS is.
Point well taken. Still, I'm slightly in favor of including this small file
with GRASS to make using what is now an essential tool easier. Even if PROJ
is updated regularly, this doesn't mean that GRASS users update their PROJ
installation. So it's likely out of sync in many cases anyway. This is a
simple text file that is easy to drop into GRASS. But of course, who should
be the one to do it so that it doesn't get way out of date.
I'm working on that now. I figured that it would be a chore and so had
avoided it. It turns out that I was right, but I'm making progress.
Michael
phone: 480-965-6213
fax: 480-965-7671
GRASS is.
file
should
I have never found it a problem that the user has to define the location
of the file if it is not in the default location. So I would rather keep
one version in proj than have to update both...
Moritz
On 12/13/06 4:46 AM, "Paul Kelly" <paul-grass@stjohnspoint.co.uk> wrote:
Hello Michael
This is very good news. The design of gis_set.tcl is difficult overall,
because it is pretty old legacy code. I'm not sure there is an easy way to
do an automatic refresh after returning from the terminal window. If there
is some kind of return code, maybe it could be bound to an update event of
some kind.
you need?
I don't know how this work. I'll look into it as I'm currently working with
this file.
I think this is an excellent suggestion. Note, however, that these files are
not in the same place on all platforms. Hamish notes that this needs to be
set in configure at compile time. If we could do as you suggest, configure
should generate an error if the relevant proj directory is not found.
Not
Agreed
This is worth following up, especially for new versions. Could you explain a
bit more.
Michael
phone: 480-965-6213
fax: 480-965-7671
I AGREE!!!
Thanks to all of you for working to make this better. A ways to go, but
improving.
Michael
phone: 480-965-6213
fax: 480-965-7671
Maris,
Just to clarify
creating a location from a georeferenced file will NOT work if you don't
have a valid database and location in .grassrc6. But it WILL work if you do
Correct?
Michael
phone: 480-965-6213
fax: 480-965-7671
(en route form offlist conversation)
Michael: As I understood, PROJSHARE is one of variable strings, that
gets replaced by exact value by make process. It's done with sed in
lib/init/Make file line 175. You can replace it by hand or run Make.
Unfortunately till weekend i will have no time to digg deeply in code,
but I THINK, that my changes in code SHOULD not affect location/mapset
ordering, as I only added crash preventing code.
About that georeferenced file problem - it's a "chicken and egg" type
problem. Currently to create new location from georeferenced file,
user needs valid location to run "g.proj -c georef=". If user has no
existing locations and only georeferenced file, user can't* create new
(first) location from that file, as he needs location to create
location from georeferenced file, what needs valid location to create
location from georeferenced file and so on in endless loop :wink:
I took short look in to "make_location_epsg.sh.in". It could be easely
converted to similar "make_location_georef.sh.it". But problem how to
notify user about failed process still remains (hint - there is some
code, that catches g.* error in gis.m mapcanvas.tcl).
* User still can create new (first) location in other ways - by EPSG
code or proj values.
IMHO for current code there is no use in including copy of proj epsg
file in GRASS. IF code is changed in such way, that allows search and
select in those epsg codes, then there could be some benefit from
keeping an fallback epsg code file inside GRASS (like, if
--with-proj-share-dir is not set, then use internal version).
Just my 0.02 cents,
Maris.
PS. I'm happy to see, that few lines of code can triger such HUGE
activity from others :wink:
the
Although
some kind.
I don't have the possibility of testing this now (since in the Linux
version all options close or enter GRASS automatically), but I seem to
remember that in the very first experimental native wingrass it was enough
to just put the mouse cursor in the GRASS database text field and press
enter and this would refresh the list of locations.
Moritz
Just a note regarding my experiences with testing various startup options
with the new data set.
It worked from the existing file smoothly, EPSG code did not work - but I think
that the recently submitted fixes from Maris should have fixed the problem (I will
update and test). The third option, leading to the old, text based interface
did not work for sp and ll but that was fixed too.
But the main reason I am writing is that when working with locations created
from the file or EPSG, the region is set to default 1,1,1 (as opposed to the
"old way" when you are required to set the default region for the new location).
This is OK if you are experienced user and you know that you have
to import something with option to expand the region to this file or to define
a meaningful "starting region" using g.region, but it may be confusing for new users.
And what I found very inconvenient was the fact already mentioned some time ago,
that you are stuck with 1,1,1 default region unless you edit the file manually
as there is no tool to modify the default region. Normally I don't use the default
region, but in this case I was using many different regions as I was importing
different types of data and it would have been nice to have a region to get back to.
Maybe just modifying the message that you get when creating the region
from file or EPSG that you need to "restart grass and define your region using
g.region" would be helpful. Of course, automatically importing the file and setting
region to its extent would be the best solution for the "new location from file"
option, becuase then the user has a new location and can display the
map right away.
It is great to see this long neglected part of GRASS moving forward
Helena
Just my 0.02 cents,
Maris.
grass-dev mailing list
grass-dev@grass.itc.it
The issue is that the default location is different on different systems.
For example, I found my epsg file in
/Library/Frameworks/PROJ.framework/Resources/proj
I have no idea where it lives on Windows, but I'll bet it's not in
/usr/local/share/proj
Michael
Moritz
phone: 480-965-6213
fax: 480-965-7671
systems. For example, I found my epsg file in
so if you were the Mac packager, you would build your binary with
./configure --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj
and then it would work for all the people who used your grass +
frameworks packages.
Same goes for the Windows binary packager, or linux, or...
if you build from source, it's up to you to tell ./configure where it
lives. If you are using a binary package it's a controlled environment.
Hamish
> :confused:
maybe this?
CVS log for grass6/lib/init/gis_set.tcl
Revision 1.41 / (as text) / (view) - annotate - [select for diffs] , Wed Dec 6 00:01:53 2006 UTC (8 days, 6 hours ago) by michael
Branch: MAIN
Changes since 1.40: +18 -26 lines
Replace exec ls with pure TclTk (glob, etc) for Windows compatibility.
Perhaps glob gives raw order?
Hamish
You are probably correct.
Michael
:confused:
maybe this?
Branch: MAIN
Hamish
phone: 480-965-6213
fax: 480-965-7671
> > :confused:
maybe this?
Branch: MAIN
According to the glob(n) manpage:
       The glob command differs from csh globbing in two ways. First, it does
       not sort its result list (use the lsort command if you want the list
       sorted). [snip]
Hamish wrote on 12/13/2006 12:10 PM:
GRASS is.
While I am also against it, I always keep GRASS PROJ stuff in sync with
GDAL (csv files).
GDAL follows which follows PROJ (same time) which follows EPSG.
