when I want to specify a column in v.db.addtable, all upper case letters in the column name get converted to lower case. I’m working on GRASS 71 (trunk). Is this an intended behaviour?
v.db.addtable map=myMap table=test layer=3 columns=“My_COL INT”
cheers,
/Johannes
hellik
October 13, 2014, 9:36am
2
Johannes Radinger wrote
in
the column name get converted to lower case. I'm working on GRASS 71
v.db.addtable map=myMap table=test layer=3 columns="My_COL INT"
cheers,
/Johannes
grass-user mailing list
grass-user@.osgeo
a quick test here with sqlite as db-backend:
v.db.addcolumn map=mybusstop@user1 columns=My_COL integer
v.db.addcolumn --verbose map=mybusstop@user1 columns=My_COL2 integer
Adding column <My_COL2> to the table
v.db.addcolumn --verbose map=mybusstop@user1 columns=My_COL3 INT
Adding column <My_COL3> to the table
db.columns table=mybusstop
cat
ROUTES
UPDATED
STREET_1
STREET_2
CAMPUS
SHELTER
BENCHES
DISPLAY_MP
SIGNS
RECEPTACLE
COMMENT_
ID
X
Y
Latitude
Longitude
Map_Size
Time_Pt
WWTm_pt
GoTri_Name
MDTm_Pt
My_COL
My_COL2
My_COL3
seems to work here.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upper-case-letters-for-defining-columns-via-v-db-addtable-tp5167120p5167156.html
hellik
October 13, 2014, 9:44am
3
also tested with dbf as db-backend:
v.db.addcolumn --verbose map=mybusstopdbf@g7 columns=My_COL4 integer
Adding column <My_COL4> to the table
db.columns table=mybusstopdbf
cat
ROUTES
UPDATED
STREET_1
STREET_2
CAMPUS
SHELTER
BENCHES
DISPLAY_MP
SIGNS
RECEPTACLE
COMMENT_
ID
X
Y
Latitude
Longitude
Map_Size
Time_Pt
WWTm_pt
GoTri_Name
MDTm_Pt
My_COL4
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upper-case-letters-for-defining-columns-via-v-db-addtable-tp5167120p5167161.html
Hi Helmut,
v.db.addcolumn is also working here.
Can you please test v.db.addtable with columns specified. This module does not work correctly in my case.
/Johannes
cat
ROUTES
UPDATED
STREET_1
STREET_2
CAMPUS
SHELTER
BENCHES
DISPLAY_MP
SIGNS
RECEPTACLE
COMMENT_
ID
X
Y
Latitude
Longitude
Map_Size
Time_Pt
WWTm_pt
GoTri_Name
MDTm_Pt
My_COL4
best regards
Helmut
Sent from the Grass - Users mailing list archive at Nabble.com .
grass-user@lists.osgeo.org
hellik
October 13, 2014, 11:41am
5
confirmed. maybe open a ticket.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upper-case-letters-for-defining-columns-via-v-db-addtable-tp5167120p5167196.html
hellik
October 13, 2014, 11:48am
6
it's maybe around
http://trac.osgeo.org/grass/browser/grass/trunk/scripts/v.db.addtable/v.db.addtable.py#L106
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Upper-case-letters-for-defining-columns-via-v-db-addtable-tp5167120p5167199.html
