Dear all,
how can I use the 'from' parameter in a python script? The following
from_range=0,255
to_range=0,511
cls.runModule('r.rescale', input=band, output=output_map_name,
from=from_range, to=to_range, overwrite=True)
causes expectedly
SyntaxError: invalid syntax
Nikos
On Wed, Mar 21, 2018 at 7:57 PM, Nikos Alexandris <nik@nikosalexandris.net> wrote:
how can I use the ‘from’ parameter in a python script? The following
from_range=0,255
to_range=0,511
causes expectedly
Try from_
. I’m not sure at this point if it works in a gunittest (which you seem to be using).
Vaclav
> from_range=0,255
> to_range=0,511
> causes expectedly
Try `from_`. I'm not sure at this point if it works in a gunittest (which
Vaclav
I already tried that and it does not work. Yes, trying to build tests for the "new" i.rgb.his.
Thank you, Nikos
Envoyé depuis mon Jolla
> from_range=0,255
> to_range=0,511
> causes expectedly
Vaclav
Nikos:
Thank you, Nikos
Note to self: `r.rescale` works fine without the `from` parameter. The actual
minimum and the maximum values, of the `input` map are always used.
Thinking about: what would be a use case where the `from` values would need
to be user defined, which implies they would need to differ from the
map's actual minimum and maximum?
If I didn't miss anything, `grep` finds only 1 use of `r.rescale` within
a script. It is the addon `grass7/raster/r.mblend/r.mblend.py`, in line
270.
Nikos
On Thu, Mar 22, 2018 at 8:21 AM, Nikos Alexandris
FYI - you can find that best with "ag - the silver searcher" since you
can restrict the search to a programming language, here --python:
270.
# core
ag --python r.rescale
gui/wxpython/iscatt/controllers.py
323: "(e. g. using r.rescale) below recommended
threshold.\n\n"
# software/grass-addons/grass7/
207: gscript.run_command('r.rescale', input=dist_high, output=weights,
So: confirmed.
[all deleted]
In the same script,
import grass.script as g
from grass.gunittest.case import TestCase
and
rescale_output = g.read_command('r.rescale', overwrite=True, verbose=True,
input=band, output=output_map_name, to=to_range)
print rescale_output
cls.runModule('r.rescale', overwrite=True, verbose=True,
the former will print the output of `r.rescale`, the latter will not.
Is there a way to get the output of `runModule`, while building a test suite?
And avoid using a `grass.script` function?
Is the purpose of `expecting_stdout=False` in `runModule()` to test if a
module emits something to stdout? [0]
Thanks, Nikos
[0] https://grass.osgeo.org/grass74/manuals/libpython/_modules/gunittest/case.html#TestCase.runModule.
On Thu, Mar 22, 2018 at 5:36 AM, Nikos Alexandris <nik@nikosalexandris.net>
suite?
It's a PyGRASS module, so just access `module.outputs.stdout` afterwards.
Please extend the documentation if needed.
Yes. It's for cases like when r.univar prints nothing when raster map
contains NULLs only (or region is outside its extent).
HTH,
Vaclav
