[GRASS-dev] user interaction with 3D vector data
Hi all!
For feedback and discussion:
Although GRASS has a great 3D vector engine, I never utilised it's power because of the lacking possibility of direct user interaction with 3D data (or have I missed something essential here?), i.e. the 3D vector data can be stored, processed by many/most vector modules and visualised within and outside GRASS, but the user cannot interact with the data.
A first step toward user interaction would be a 2D viewer (or several simultaneous) that can be moved in the 3D vector space to look at (artificial) sections through the data (section needs not to be vertical to the Earth's surface). A second step would be the possibility to edit the vector data in these artificial sections at the cut-points and lines (and close-by nodes projected into the section). Together with existing and possibly new complementary tools for interpolation, surface generation (e.g. between sections) and autogeneration of volumes, this would be a very powerful tool. Alternatively, such a functionality can be integrated in a 3D viewer.
An obvious application for this is the construction of a 3 dimensional vector-"models" from several intersecting profiles (e.g. geology, spatial planning, etc.). According to the GRASS7 ideas collection, this has been considered before - see GRASS 7 ideas collection - GRASS-Wiki : "2d 'vertical' vector data (e.g. Geologic Cross Sections)" (What is the problem here, isn't a section the same as a number of faces in 3D space?).
Are there more users/developers who miss this kind of functionality?
What are your thoughts?
Henning
