[GRASS-dev] Using DDD or other Debugger for GRASS Code
Greetings
I need to make some debugging for a few C functions in GRASS. Is it possible to use DDD? Or what other debugger do you advise?
Thanks~
Franz
to use DDD?
DDD is just a front-end to gdb (etc). There shouldn't be any problem
using it with GRASS.
Glynn:
any problem using it with GRASS.
[ see DDD instructions @ http://grass.osgeo.org/wiki/Bugs ]
