[GRASS-dev] using g.mapset to create new mapset
Dear devs,
When using g.mapset with the -c flag a new mapset should be created, e.g.,
g.mapset -c mapset=tutorial location=nc_spm_08_grass7
This does create a new folder 'tutorial' within the nc+spm_08_grass7 location. However, the folder is empty. Just checking if I miss something before filing a bug report.
I am using self-compiled grass7 master on Ubuntu 16.04
On 04/04/17 17:00, Paulo van Breugel wrote:
Dear devs,
I cannot confirm with recent trunk:
> g.mapset -c test
> ls /data/GRASS/DATA7/nc_spm_08/test
WIND
So, the mapset contains what is necessary, i.e. the WIND file. What else were you expecting in an empty mapset ?
Moritz
Dear devs,
> g.mapset -c test
WIND
It works for me if I am creating a new mapset in the same location, but not if I create a mapset in another location, like below:
> g.mapset -c mapset=test location=nc_basic_spm_grass7
Gives me a new empty (i.e., no WIND file) folder 'test' in the location folder of nc_basic_spm_grass7. Does this work for you?
Moritz
Dear devs,
e.g.,
g.mapset -c test
WIND
No, I can confirm the problem. g.region -d fixes it, but it shouldn't be necessary. Probably warrants a bug report.
Moritz
OK, done,
Dear devs,
e.g.,
This does create a new folder ‘tutorial’ within the nc+spm_08_grass7
g.mapset -c test
WIND
Gives me a new empty (i.e., no WIND file) folder ‘test’ in the location
No, I can confirm the problem. g.region -d fixes it, but it shouldn’t be necessary. Probably warrants a bug report.
#3326
Moritz
