[GRASS-dev] Using --quiet flag in grass.run_command
Greetings
I’m running a few functions inside grass.run_command and I wanted to use the --quiet flag but I cannot find any information about it. I have tried flag=‘q’, flag=‘–quiet’ and jut ‘–quiet’ but non of these are accepted.
Can anyone give me an hand?
Thanks
Helena
2010/10/18 Helena Herrera <helenaherrera1980@gmail.com>:
I'm running a few functions inside grass.run_command and I wanted to use the
flag='q', flag='--quiet' and jut '--quiet' but non of these are accepted.
use `quiet` flag instead, e.g.
grass.run_command(v.build, map = "name", quiet = True)
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
Similarly, "verbose = True" for --verbose and "overwrite = True" for
--overwrite.
Hi there
I have tried:
check_input= grass.run_command(“g.findfile”, element=‘cell’, file=i, mapset=mapsetc, quiet=“True”)
and I still got that boring print . What am I missing?
Thanks
On Mon, Oct 18, 2010 at 11:06 AM, Glynn Clements <glynn@gclements.plus.com> wrote:
–quiet flag but I cannot find any information about it. I have tried
use quiet flag instead, e.g.
grass.run_command(v.build, map = “name”, quiet = True)
Similarly, “verbose = True” for --verbose and “overwrite = True” for
–overwrite.
check_input= grass.run_command("g.findfile", element='cell', file=i,
mapset=mapsetc, quiet="True")
verbosity level (quiet/verbose) only affects printing
messages/warnings. In this case 'g.findfile' prints its output to
stdout, so it's printed regardless of quite or verbose flags.
Run
file = grass.read_command('g.findfile', element = 'cell', file='x',
quiet = True)
print file
or better grass.find_file directly (interface for 'g.findfile')
file = grass.find_file(element = 'cell', name = 'x')
print file
Martin
In some functions, for instance g.remove even after using quiet=True ther warnings are still beng printed. was tha expected?
Regarding GDALWARP, I’m running this command:
grass.debug(“gdalwarp -t_srs %s -srcnodata %s -dstnodata %s -tr %s %s %s %s” % (proj_location, no_value, no_value, t_srx, t_sry, input, tempfile))
can I use something in order to avoid all the printing that this does?
On Mon, Oct 18, 2010 at 1:23 PM, Martin Landa <landa.martin@gmail.com> wrote:
[please keep discussion on ML]
Maybe I was not clear. What GRASS is doing is printing and I don’t want ot
print those messages. So, what you are saying is that I’m not able to avoid
the printing og g.findfile?
as I wrote in the previous mail use grass.find_file(). Seems to me
that I am not understanding well, running
grass.run_command(‘g.findfile’, …, stdout = file(os.devnull, ‘w’))
is quite meaningless.
Martin
--quiet suppresses messages; it doesn't suppress warnings.
Regarding GDALWARP, I'm running this command:
grass.debug("gdalwarp -t_srs %s -srcnodata %s -dstnodata %s -tr %s %s %s %s"
You can redirect stdout and/or stderr to the null device (/dev/null on
Unix, "nul" on Windows), e.g.:
  nullf = open(os.devnull, 'w')
  grass.run_comand(..., stdout = nullf, stderr = nullf)
  nullf.close()
