[GRASS-dev] Using the pygrass "Mapset.glist" method and a dictionary
Hi list.
In a Python script, I use the following pygrass method to retrieve a list of
raster maps:
  from grass.pygrass.gis import Mapset
  landsat_imagery = dict()
  landsat_imagery['Spectral Bands'] = Mapset().glist('rast', pattern =
'B[123457]')
However, whenever the result is empty, i.e. there are no B1, B2 and so on
named raster maps, running the script fails with the error:
'B[123457]')
  TypeError: 'str' object is not callable
Running the instructions step-wise, from within ipython, doesn't appear to be
problematic. What am I missing in this case?
Thank you for any hints, Nikos
Ciao Nikos,
On Thursday 23 May 2013 22:50:10 Nikos Alexandris wrote:
Hi list.
raster maps:
'B[123457]')
'B[123457]')
be problematic. What am I missing in this case?
Mmh...
I've tried your code... and it is working on my machine. In both: python shell
and from file...
Python shell:
Mapset().glist('rast', pattern = 'B[123457]')
['B4', 'B5', 'B1', 'B3', 'B2', 'B7']
From file:
cat nik.py
                                                   pattern='B[123457]')
print landsat_imagery
%run nik.py
{'Spectral Bands': ['B4', 'B5', 'B1', 'B3', 'B2', 'B7']}
Therefore I think that the problem is not here...
can you send me or share/publish the whole code somewhere (gist.github, dpaste
or other).
Pietro
On Friday 24 of May 2013 00:23:28 Pietro Zambelli wrote:
Ciao Nikos,
Ciao Pietro,
> 'B[123457]')
Mmh...
shell and from file...
Python shell:
This should be empty! From the above result it means that the requested bands
pre-exist. Consider a Mapswet with bands named like B10, B20, B30, B40, B50,
B70, B80.
(Sure, we can erase that ending "0" while importing, for example, Landsat
bands in GRASS, but... who knows, maybe someone needs to respect the original
naming pattern of old Landsat scenes.)
From file:
>>> cat nik.py
>>> %run nik.py
Here too, it should be empty.
dpaste or other).
Grazie, Nikos
[all deleted]
@Pietro: I think I have messed up in trying to integrate a dictionary (as you
correctly recommended last week, off-list communication) in some functions.
Using simple lists is for me easier. However, I recognise the advantages in
using a dictionary and want to incorporate it.
Sensing you of list the latest code...
Thank you, Nikos
On 23/05/13 21:50, Nikos Alexandris wrote:
Hi list.
raster maps:
'B[123457]')
'B[123457]')
I can't reproduce this:
>>> landsat_imagery
>>> landsat_imagery['Spectral Bands'] = Mapset().glist('rast', pattern = 'B[123457]')
>>> landsat_imagery
{'Spectral Bands': }
So even with an empty result of the glist call, I don't get an error message.
Moritz
> of>
> raster maps:
> 'B[123457]')
> 'B[123457]')
>>> landsat_imagery
= 'B[123457]')
>>> landsat_imagery
message.
Right! I committed a classical beginner's mistake, that is right after
importing
I used "Mapset", (outside of the function in which I used the above mentioned
code) as
  gisenv = grass.gisenv()
  Mapset = gisenv['MAPSET']
This naturally lead to the reported error. I found the question
<http://stackoverflow.com/q/10775541/1172302&gt; to be helpful.
Thanks, Nikos
