is missing in the 6.4 release branch for the interface description of layer in v.db.addtable around line 36. It is in trunk, and in 6.4.1 released. Without it, the type is inferred to be string.
Roger
Roger Bivand
Department of Economics, NHH Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand@nhh.no
fixed in r48304.
Note that in GRASS7 layer is a string. It supports layer names (not
only layer numbers) and OGR layer names when accessing external data
directly using OGR [1].
fixed in r48304.
Thanks, see below.
It is in v.in.ogr etc. But in trunk/scripts/v.db.addtable/v.db.addtable.py
line 35 is #% type: integer for layer - was this intended?
v.db.addtable --interface-description
<parameter name="layer" type="integer" required="no" multiple="no">
<description>
Layer number where to add new attribute table
</description>
<default>
1
</default>
<guisection>
Definition
</guisection>
</parameter>
v.to.db --interface-description
<parameter name="layer" type="string" required="yes" multiple="no">
<label>
Layer number or name (write to)
</label>
<description>
A single vector map can be connected to multiple database tables. This number determines which table to use. Layer name for direct OGR access.
</description>
<gisprompt age="old" element="layer" prompt="layer" />
<default>
1
</default>
</parameter>
The 6/7 change here breaks spgrass6 and forces version check, so I'd rather I could rely on layer always being integer in 6 and string in 7 everywhere it occurs.
yes, it's an exception, layer number must be defined somehow.
