[GRASS-dev] v.buffer doesn't respect region?
The short answer is yes, it will be difficult. The GRASS-internal
vector buffering algorithm has a number of bugs, the only vector
buffering method that is AFAICT bug-free is v.buffer in trunk with
GEOS support which uses the GEOS buffering algorithm which in turn
does not (yet?) support geodesic distances in latlong.
Markus M
I was just using v.buffer yesterday, and found it was ignoring my region settings, it processed the entire map instead of a small area.
I updated GRASS yesterday, and am compiled with GEOS. Am I missing something else, should v.buffer respect the region?
-Eric
To my knowledge no. As before, all vector modules work on full maps while
raster operations are done in the computational region (with a few exceptions).
To limit a vector area you need to clip it first (e.g., v.in.region +
v.overlay/v.select).
