I would like to add a comment in the metadata of a generated vector
map but the content is shortened. I'm in the NorthCarolina mapset,
from an ipython shell:
In [1]: !v.buffer --overwrite input=busroute6@PERMANENT
output=buff__busroute6 distance=10
In [2]: !v.info buff__busroute6
| Mapset: user1 |
| Database: /home/pietro/docdat/gis/ |
| Title: NC State University bus service Wolfline route 6 (lines m |
| Map scale: 1:1 |
| Name of creator: helena |
| Organization: NC OneMap |
| Source date: Thu Mar 15 23:35:50 2007 |
| Timestamp (first layer): none |
| Map format: native |
| Type of map: vector (level: 2) |
| Number of points: 0 Number of centroids: 1 |
| Number of lines: 0 Number of boundaries: 36 |
| Number of areas: 4 Number of islands: 4 |
| Map is 3D: No |
| Number of dblinks: 0 |
| Projection: Lambert Conformal Conic |
| N: 227741.05646361 S: 226151.51091547 |
| E: 639360.09470206 W: 635143.56812813 |
| Digitization threshold: 0 |
| Comment: |
The command that generate the map is missing!
Should I open a ticket on v.buffer?
Let's add the command manually:
In [3]: from grass.pygrass.vector import VectorTopo
In [4]: with VectorTopo('buff__busroute6') as buff:
....: buff.comment = 'v.buffer --overwrite
input=busroute6@PERMANENT output=buff__busroute6 distance=10'
....: buff.write_header()
In [5]: !v.info buff__busroute6
| Mapset: user1 |
| Map scale: 1:1 |
| Map is 3D: No |
| Comment: |
| v.buffer --overwrite input=busroute6@PERMANENT output=buff__busroute6 |
As you can see the Comment string is shortened...
but in the header file is written correctly:
In [6]: !cat /nc_spm_08_grass7/user1/vector/buff__busroute6/head
ORGANIZATION: NC OneMap
DIGIT DATE: Mar 16 7
DIGIT NAME: helena
MAP NAME: NC State University bus service Wolfline route 6 (lines map)
MAP DATE: Thu Mar 15 23:35:50 2007
MAP SCALE: 1
OTHER INFO: v.buffer --overwrite input=busroute6@PERMANENT
PROJ: 99
ZONE: 0
MAP THRESH: 0.000000
Instead the raster equivalent: r.info it is able to handle a long line.
In [11]: !r.info elevation
| Map: elevation Date: Tue Nov 7 01:09:51 2006 |
| Mapset: PERMANENT Login of Creator: helena |
| DataBase: /home/pietro/docdat/gis/ |
| Title: South-West Wake county: Elevation NED 10m ( elev_ned10m ) |
| Timestamp: none |
| Type of Map: raster Number of Categories: 255 |
| Data Type: FCELL |
| Rows: 1350 |
| Columns: 1500 |
| Total Cells: 2025000 |
| N: 228500 S: 215000 Res: 10 |
| E: 645000 W: 630000 Res: 10 |
| Range of data: min = 55.57879 max = 156.3299 |
| Data Description: |
| generated by r.proj |
| Comments: |
| r.proj input="ned03arcsec" location="northcarolina_latlong" mapset="\ |
| helena" output="elev_ned10m" method="cubic" resolution=10 |
should I open a bug on this?
Best regards
Pietro
