Hi all.
AFAIK, v.buffer has been deprecated, and replaced by v.buffer2. As a
result, the qgis-plugin-grass cannot use the command anymore. Of course
it is possible and esy to replace the command, but care should be taken
when linking to different grass versions. Wouldnì't it be easier/more
robust to either change the name of the new module back to v.buffer, or
to ln?
See: https://trac.osgeo.org/qgis/ticket/1629
All the best.
On Thu, Apr 23, 2009 at 8:50 AM, Paolo Cavallini <cavallini@faunalia.it> wrote:
Hi all.
Yes.
As a result, the qgis-plugin-grass cannot use the command anymore.
Of course it is possible and esy to replace the command, but care should be taken
to ln?
This is the case:
cat vector/v.buffer2/Makefile
MODULE_TOPDIR = ../..
PGM = v.buffer
The new version is called v.buffer as before (obviously).
OK, I found the problem:
# GRASS 6.3, http://grass.osgeo.org/grass63/manuals/html63_user/v.buffer.html:
buffer=float
Buffer distance in map units
# GRASS 6.4, http://grass.osgeo.org/grass64/manuals/html64_user/v.buffer.html:
distance=float
Buffer distance along major axis in map units
This is bad.
Options:
- QGIS updates its toolbox XML file to rename the parameter
- GRASS 6.4+ renames back "distance" to "buffer"
Thanks for pointing out.
Markus Neteler ha scritto:
This is bad.
Options:
I would suggest the second, as it is simpler and keeps compatibility,
not only with QGIS.
Please let me know how you intend to proceed, so I can take the right
action.
All the best, and thanks.
On 23.04.2009 10:53, Markus Neteler wrote:
This is bad.
Options:
I think that the second option would be better. Users might have scripts
which use the old syntax. Aren't we supposed to be more or less
backwards compatible within a major version? However distance is a more
"proper" name for the parameter IMHO. So keep it as distance in 7 maybe?
--Wolf
<:3 )---- Wolf Bergenheim ----( 8:>
2009/4/23 Wolf Bergenheim <wolf+grass@bergenheim.net>:
+1 for 'distance' in GRASS7.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
