[GRASS-dev] v.build on a broken vector -> coor files of vector is larger than it should be
Maciej Sieczka wrote:
Agustin Diez Castillo wrote:
v.build map=ACas260207b@adiez2 option=build
and not results, well yes those:
coor files of vector 'ACas260207b@adiez2' is larger than it should be
(15145471 bytes excess).
This problem can be solved if you just open the vector in v.digit and
quit. That will fix the vector.
BTW - does anybody know why this trick is actually needed? Why does
v.build output a coor file larger than necessary?
Maciek
