Can anybody possibly explain why does the "Attaching islands..." in
v.build take so very long compared to other operations?
For example: I have a big vector map consisted only of lines, more than
180 000 of them. v.build on this dataset takes about 20 seconds. After
converting lines into boundaries (v.type), v.build on that new vector
map made of boundaries only takes half a day, with 99% of processing
time dedicated to "Attaching islands...". Is that normal? Any
improvements possible?
the not-thinking-about-it-much guess is to blame the "florida coastline"
problem. to test is that is the problem, try running 'v.split vert=1000'
before v.type and see if it still takes a long time.
v.build take so very long compared to other operations? For
After converting lines into boundaries (v.type), v.build on that
new vector map made of boundaries only takes half a day, with 99%
of processing time dedicated to "Attaching islands...". Is that
normal? Any improvements possible?
coastline" problem. to test is that is the problem, try running
'v.split vert=1000' before v.type and see if it still takes a long
time.
'v.split vert=1000' reduces the processing time from over 10 hours to 10
minutes. Strange world we live in.
Hamish:
> time.
10 minutes. Strange world we live in.
"v.in.ogr
It would be useful to split long boundaries to smaller
pieces. Otherwise cleaning process can become very slow because
bounding box of long boundaries can overlap large part of the map (for
example outline around all areas) and cleaning process is checking
intersection with all boundaries falling in the bounding box."
"v.in.ogr -------- It would be useful to split long boundaries to
smaller pieces. Otherwise cleaning process can become very slow
because bounding box of long boundaries can overlap large part of the
map (for example outline around all areas) and cleaning process is
checking intersection with all boundaries falling in the bounding
box."
Skiming through GDAL 1.6 announce I noticed the following:
"Add a segmentize() method to OGRGeometry to modify the geometry such it
has no segment longer then the given distance; add a -segmentize option
to ogr2ogr"
to ogr2ogr"
Relevant?
perhaps, but distance would need to by by number of vertices, not map
distance - as maps can be of many scales and there is no single "max
distance". (I guess you could calculate map bounds and use 5% of max
side..) And you'd need a GDAL version check to stay backwards compatible
with older GDALs for the next 2-3 years or so. (extended Debian life cycle)
but I wonder, would a simple, but large, box of 4 vertices (corners) which
surrounds a complicated vector map (many islands) still take so long to
build? in that case, reducing the number of sequential vertices wouldn't
help.
probably need to run some trials with v.in.region + v.patch to test that.
