[GRASS-dev] v.category: opt=del was changed
Recent commits changed v.category opt=del behaviour.
Before:
$ v.random out=pts n=3
$ v.category opt=print in=pts
1
2
3
$ v.category opt=del in=pts out=pts_delcat
$ v.category opt=print in=pts_delcat
No output, i.e. v.category opt=del removed them all.
Now:
1
2
3
2
3
I.e. only category "1" is removed.
Such a change in user interface is not acceptable for GRASS 6. By
default all categories should be selected. I don't see a reason to
change the default behaviour in GRASS 7 either.
Maciek
Maciej Sieczka
www.sieczka.org
2008/12/6 Maciej Sieczka <msieczka@sieczka.org>:
1
2
3
2
3
yes, only cat '1' is removed ('1' is default value for 'cat' parameter)
to remove all categories use 'cat=-1'
well, you are right (reverted r34750).
new behaviour can be useful if you want to remove not all categories,
but only selected one (well, you can always use v.edit for that).
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Martin Landa pisze:
Cool.
So, given that v.edit already provides the functionality of removing
selected categories only (tool=catdel cats=), I suggest to revert to old
v.category opt=del behavior in GRASS 7 as well. There is no big enough
reason to change the interface in this regard IMO. I don't insist though.
Maciek
Maciej Sieczka
www.sieczka.org
Maciek:
Martin:
perhaps we should better define what the modules are supposed to do.
v.edit is clearly for incisive/targeted edits to a vector map, so at
the other end we could promote v.category as the general purpose/bulk
category maintenance tool. This would mean less for learning curve
required, and less opportunity for new user confusion.
In the same vein I wonder if the new v.cat ids= option offers anything new;
IMO such raw/low-level stuff should be held for advanced use in v.edit.
e.g. the v.cat module description explains what the cat is by calling it
a type of ID number. And then we provide both cat= and and ids= options.
What's a non-ultra-power user to think?
I've now added a line in the help page to explain cat=
2c,
Hamish
2008/12/7 Hamish <hamish_b@yahoo.com>:
Maciek:
Martin:
v.category seems to be designed to edit vector layer categories
globally (all features in given layer). I have added 'id' parameter
because of v.edit-based wxGUI digitizer. This part has been already
removed from wxGUI. So not needed any more. From this perspective,
'id' parameter could be removed from v.category. If user want to
add/delete category(ies) only for subset of features v.edit can be
used.
From this point of view I would suggest to remove 'id' parameter from
v.category and change 'del' in G7 to delete categories globally in
given layer.
Martin
