WARNING: Vector map <vnir4567_seg_0_no_small_areas> already exists and will be overwritten
Copying features…
Rebuilding parts of topology…
Building topology for vector map vnir4567_seg_0_no_small_areas@PERMANENT…
Registering primitives…
19070 primitives registered
187624 vertices registered
Building areas…
5344 areas built
251 isles built
Attaching islands…
Attaching centroids…
Number of nodes: 8636
Number of primitives: 19070
Number of points: 0
Number of lines: 0
Number of boundaries: 13729
Number of centroids: 5341
Number of areas: 5344
Number of isles: 251
Tool: Remove small areas
ERROR: Area merging failed
Copying features…
Building areas…
5344 areas built
251 isles built
Attaching islands…
Number of points: 0
Number of lines: 0
On Tue, Dec 31, 2013 at 5:23 AM, Yann Chemin <ychemin@gmail.com> wrote:
(SVN G7)
it does work with thres inferior to 600, but not above...
v.clean input=vnir4567_seg_0 output=vnir4567_seg_0_no_small_areas type=area
tool=rmarea thres=10000.00 --overwrite
Tool: Threshold
Remove small areas: 10000
be overwritten
Copying features...
Rebuilding parts of topology...
<vnir4567_seg_0_no_small_areas@PERMANENT>...
Registering primitives...
Building areas...
5344 areas built
251 isles built
Attaching islands...
Attaching centroids...
Number of points: 0
Number of lines: 0
