martinl
November 30, 2013, 11:26am
1
recently I found problem when breaking lines using `v.clean`.
I have a patched map that contains boundaries and centroids.
$ v.info x3 -t
nodes=8219
points=0
lines=0
boundaries=11807
centroids=4876
areas=4875
islands=1222
primitives=16683
map3d=0
When I try to break lines on intersections `v.clean` fails because it
tries to read nodes from centroids (which obviously fails).
$ v.clean in=x3 out=x4 tool=break --o
Tool: Break lines at intersections
0..ERROR: Nodes not available for line 11725
Defining `type` explicitly helps
$ v.clean in=x3 out=x4 tool=break --o type=boundary
In the attachment you can find a patch which seems to fix this issue.
I am just not sure about possible side-efects.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
(attachments)
break_lines.diff (684 Bytes)
On Sat, Nov 30, 2013 at 12:26 PM, Martin Landa <landa.martin@gmail.com> wrote:
$ v.info x3 -t
nodes=8219
points=0
lines=0
boundaries=11807
centroids=4876
areas=4875
islands=1222
primitives=16683
map3d=0
Fixed in r58340, please test.
Markus M
martinl
November 30, 2013, 5:02pm
3
Hi Markus,
2013/11/30 Markus Metz <markus.metz.giswork@gmail.com>:
thanks for super-quick fix! It seems to be OK, I found similar problem
in `merge_lines.c` (see the attached patch).
Martin
(attachments)
merge_lines.diff (408 Bytes)
On Sat, Nov 30, 2013 at 6:02 PM, Martin Landa <landa.martin@gmail.com> wrote:
Hi Markus,
Fixed in r58341 (it's the same fix as for breaking lines).
Markus M
Hi Markus,
How did you discover that bug in Vect_merge_lines()? To my knowledge
all modules calling Vect_merge_lines() set the correct type (lines
and/or boundaries).
Markus M
Hi Markus,
and/or boundaries).
by `v.clean tool=snap -c`, see [1].
Martin
[1] http://trac.osgeo.org/grass/browser/grass/trunk/vector/v.clean/main.c#L407
On Mon, Dec 2, 2013 at 4:21 AM, Martin Landa <landa.martin@gmail.com> wrote:
Hi Markus,
and/or boundaries).
Oops. Thanks for spotting this!
Markus M
Martin
