any reason why 'v.clean tool=rmline' doesn't respect thresh= to remove small lines? (like rmarea) Or is it just a matter of writing the code? http://trac.osgeo.org/grass/changeset/24404
rmline should remove only collapsed lines/boundaries (zero-length). To
clean map geometry.
It would be possible to modify rmline tool in v.clean to be
thresh-sensitive. Since v.edit do the job in the better way I think we
can leave rmline as it is.
> the code?
Martin:
To clean map geometry.
to remove all lines/boundaries shorter than $thresh
v.edit a1 tool=delete query=length type=line,boundary thresh=-$thresh
Excellent. Thanks.
longer than $thresh
(did you mean "thresh=$thresh" or "thresh=+$thresh" ?)
we can leave rmline as it is.
ok, but it's a bit inconsistent.
Hamish
____________________________________________________________________________________
Never miss a thing. Make Yahoo your home page. http://www.yahoo.com/r/hs
sorry, typo, I meant thresh=$thresh (or thresh=+$thresh)
> > thresh=-$thresh
Hamish:
> Excellent. Thanks.
> > longer than $thresh
> > thresh=-$thresh
M:
> > think we can leave rmline as it is.
H:
M:
to rename rmline, to rmzeroline ?
I thought it might be nice to eventually add thresh support to
v.clean's rmline, even if it is a redundant method. tool=rmline is
redundant too (v.edit thresh=0.0), so it's no worse... I hesitate to
even suggest this, but even as an embedded system("v.edit query=length
thresh=%f", ...). Well probably a bad thing to do that but I don't
think reimplementing it is enough lines of code to worry about the
evils of code duplication or moving it to a common lib fn.
Hamish
