I was looking for a tool which would snap nodes of separate lines, to
connect them into one line. v.clean tool=snap however snaps any
vertices, not only nodes. Is it a bug? If not, I'd like to fill a wish
for a new v.clean tool that would snap *only nodes* (of separate lines,
so that the line would not snap to itself if the threshold was bigger
than the line's lenght) within the threshold, *leaving other vertices
alone*. Before doing that I'm asking for your opinion on whether such a
tool would make sense for others, and if v.clean is the right module to
ask for implementing such functionality.
lines, so that the line would not snap to itself if the threshold was
bigger than the line's lenght) within the threshold, *leaving other
vertices alone*.
create a new line to connect the nodes within a treshold? no vertices
are moved, only new connecting lines added. (v.distance??)
or allow movement of the end nodes but not non-node vertices?
