[GRASS-dev] v.db.addtable turns column headers in lower case
If I add a new table to a vector layer, column names are always in lower case, even if defined with capital letters. For example:
{{{v.db.addtable map=test table=test columns=“TEST1 INTEGER,TEST2 VARCHAR(25)”}}}
Results in a table with the columns “cat”, “test1”, “test2”. Is this intentional?
Adding columns to a table withv.db.addcolumn does not show this behavious (i.e., it will retain capitalization of column headers).
