[GRASS-dev] v.db.calc
Moritz wrote:
I think that with the move in 6.4 to SQLite as default db
backend,
DBF remains the default in 6.x, see include/dbmi.h "DB_DEFAULT_DRIVER".
It is only changed to sqlite in grass7.
todo: for sqlite decide if we want per-map DB files like with DBF or
single DB file per mapset. I'd vote for per-map files so it takes longer
to reach any 32bit filesystem filesize limits, limits the effect of DB
corruption, and makes it easier to move maps around, but then I don't do
any fancy joins etc that might take advantage of a single file per mapset
approach.
Hamish
2009/5/7 Hamish <hamish_b@yahoo.com>:
backend,
Probably we could move to SQLite in GRASS 6.5. Note there are still
remaining bugs, e.g. v.dissolve doesn't work on string column.
approach.
I would vote for both approaches. User can decide what he prefers via
environmental variable, e.g. GRASS_SQLITE_PER_MAPSET.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
>> backend,
> approach.
There's no reason to use an environment variable. This should be dealt
with by the database setting (VAR or dblink). If it refers to a
directory, use a <mapname>.db file for each map. Otherwise treat it is
the name of an SQLite database file to use for all maps.
2009/5/7 Glynn Clements <glynn@gclements.plus.com>:
Right.
M.
On Thu, May 7, 2009 at 1:45 PM, Martin Landa <landa.martin@gmail.com> wrote:
backend,
Don't remember - is there a ticket?
