#%option
#% key: value
#% type: string
#% description: Value to update the column with, can be (combination of) other column(s)
#% required : no
#%end
#%option
#% key: qcolumn
#% type: string
#% description: Column to query
#% required : no
#%end
'qcolumn' was added in a later stage, AFAIK mostly because of a misunderstanding of 'value'. As said in the help text, value can be either a value, a name of another column or a combination of other columns, so it already comprises qcolumn.
However, in its current version (since rev 23578), value is now adapted according to column type, which means that you cannot use column operations on varchar columns (e.g. concatenation).
So, we should either:
- change the doc to reflect that value should only be a nominal value, or
- go back to the original, i.e. no qcolumn and no type checking for value, so that it's up to the user to use correct quoting
On Tue, Sep 30, 2008 at 10:58 AM, Moritz Lennert
<mlennert@club.worldonline.be> wrote:
In v.db.update we currently have:
#%option
#% key: value
#% type: string
other column(s)
#% required : no
#%end
#%option
#% key: qcolumn
#% type: string
#% required : no
#%end
Only today I learned that (I added qcolumn if I remember correctly)
yes
No - I don't find it obvious at all that "value" could be a column name.
qcolumn also exists in other commands AFAIK, to that's consistent.
yes
Another option: add expression=, which is just used verbatim as the
RHS of the assignment (you can already use qcolumn= this way, but its
name and description makes that counter-intuitive). Optionally remove
value= and/or qcolumn=.
this puts it at odds with the value= option description, both WRT quotes
and combinations:
"Value to update the column with (varchar values have to be in single
quotes, e.g. 'grass'), can be (combination of) other column(s)"
value, or
Markus:
> yes
> name.
Glynn:
Optionally remove value= and/or qcolumn=.
Replacing qcolumn= with expression= sounds good to me. It's more to the
point.
At which point value= becomes a little redundant, but it helps to avoid
a some minor 'quote' proofing when used from the shell.
yes
That was what the original value= was for, admittedly with a bad choice of parameter name.
