[GRASS-dev] v.db.update: any reason to keep both value and qcolumn parameter ?
voice: 480-965-6262; fax: 480-965-7671
On Sep 30, 2008, at 8:48 AM, <grass-dev-request@lists.osgeo.org> <grass-dev-request@lists.osgeo.org > wrote:
Date: Tue, 30 Sep 2008 15:44:48 +0100
Subject: Re: [GRASS-dev] v.db.update: any reason to keep both value
To: "Markus Neteler" <neteler@osgeo.org>
Cc: grass-dev <grass-dev@lists.osgeo.org>
Message-ID: <18658.15200.914210.187542@cerise.gclements.plus.com>
Content-Type: text/plain; charset=us-ascii
Markus Neteler wrote:
However, in its current version (since rev 23578), value is now adapted
according to column type, which means that you cannot use column operations
on varchar columns (e.g. concatenation).
So, we should either:
- change the doc to reflect that value should only be a nominal value, or
yes
- go back to the original, i.e. no qcolumn and no type checking for value,
so that it's up to the user to use correct quoting
No - I don't find it obvious at all that "value" could be a column name.
qcolumn also exists in other commands AFAIK, to that's consistent.
Another option: add expression=, which is just used verbatim as the
RHS of the assignment (you can already use qcolumn= this way, but its
name and description makes that counter-intuitive). Optionally remove
value= and/or qcolumn=.
From a usability perspective, I think expression= is much better and more understandable than value= and qcolumn=. I've regularly been confused by these.
Michael
