[GRASS-dev] v.digit and region
Hamish,
Regarding your recent fix for v.digit:
Log Message:
restore original region and clear screen on exit.
I think the real problem about v.digit is that it changes resolution
during the digitizing session, not that it changes the region extent.
The latter one, I even like - you can stop digitizing, do some data
viewing in the given location and restart digitizing from the same
place.
Do you think it would be hard to prevent v.digit from changing the
resolution instead of just reverting original region at quit? For me,
it is huge disadvantage that the background map resolution changes as I
zoom in and out in v.digit (not mentioning that it might lead to
crashes in some cases - somehow when the resolution goes too fine
v.digit can't cope with that). And I'd revert to letting the region
extents to change as I pan in v.digit, that's cool.
https://intevation.de/rt/webrt?serial_num=3047
https://intevation.de/rt/webrt?serial_num=2962
Maybe related:
https://intevation.de/rt/webrt?serial_num=3164
What do you think?
Maciek
CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
ZAPRASZAMY
www.skarpatravel.pl
> Log Message:
place.
I agree this is a bad problem. The resolution gets changed because the
zoomed rows and columns are not adjusted to it -- the resolution is
changed to meet the new number of rows,columns so it ends up slightly
off.
"g.region -a" fixes it from the command line:
general/g.region/cmd/main.c
/* res= */
       if (!G_scan_resolution (value, &x, window.proj))
            die(parm.res);
       window.ns_res = x;
       window.ew_res = x;
       if (flag.res_set->answer) {
          window.north = ceil(window.north/x) * x ;
          window.south = floor(window.south/x) * x ;
          window.east = ceil(window.east/x) * x ;
          window.west = floor(window.west/x) * x ;
/* nsres= [same for ewres=, tbres=] */
           die(parm.nsres);
  window.ns_res = x;
      window.north = 2 * x * ( (int)(window.north/2/x));
      window.south = 2 * x * ( (int)(window.south/2/x));
I am not sure which is the best approach.
I've never been very happy with int = (int)(float + 0.5); for rounding
either -- i.e. it goes wrong if your float is negative?
guidance?
G_adjust_Cell_head3() is constrained by the fact that rows,cols must end
up as an integer but resolution may be float. If they don't agree, guess
who gets changed? [software generally follows the path of least work]
I think it should do both.
For me, it is huge disadvantage that the background map resolution
changes as I zoom in and out in v.digit (not mentioning that it might
lead to crashes in some cases - somehow when the resolution goes too
fine v.digit can't cope with that). And I'd revert to letting the
region extents to change as I pan in v.digit, that's cool.
Maybe related:
these are both symptoms of the same bug; reports merged.
What do you think?
I think that only g.region and d.zoom should be allowed to change the
mapset's region permanently. All other modules should leave the system
in the same state as they found it.
G_put_window()'s help comments support this:
* <b>Warning.</b> Since this routine actually changes the database region, it
* should only be called by modules which the user knows will change the region.
* It is probably fair to say that under GRASS 3.0 only the <i>g.region</i>,
* and <i>d.zoom</i> modules should call this routine.
Usually a module would use G_set_window() to change the region -- the
difference being that this only persists within the module and the WIND
file is not touched. Apparently (but I am not sure about this) this
doesn't survive the C->Tcl back and forth so v.digit has to use
G_put_window()? It runs both, I'm not sure what happens if you comment
out the G_put_window()s.
in lib/gis/ have a read though the header comments in:
align_window.c get_window.c put_window.c set_window.c adj_cellhd.c
Hamish
guidance?
  int = (int) floor(float + 0.5);
A program which needs to run other modules with a different region
should use either GRASS_REGION or WIND_OVERRIDE.
Definitely.
If WIND_OVERRIDE is set, G_put_window() will modify the named region
specified by that variable rather than the WIND file.
For v.digit, using GRASS_REGION is probably more appropriate, although
slightly more work (AFAIK, you have to construct the string yourself).
