[GRASS-dev] v.digit and v.edit wiki discussion
I started Wiki page, which should specify future tool, which would
replace current v.digit module [1].
IMHO future v.digit should be based on v.edit module for geometry
operations and db.* modules for database management. Current version of
v.edit supports only two operations: add and delete. In the wiki, I
tryed to define desired behavior of the module, so it would be usable
for real editing of vector data.
Help with this documentation and with coding welcome! Wolf, initial
author of v.edit, did great job. v.edit has IMHO nice design. Most of
the functions can be adopted from v.in.ascii.
Please add your notes or completions to Wiki and if you can, drop some
pieces of code to vector/v.edit/* :wink:
Jachym
[1] http://grass.gdf-hannover.de/wiki/GRASS_Digitizing_tool
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
OFFICE:
Department of Geoinformation Technologies
Zemedelska 3
613 00, Brno
Czech Republick
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
How will this relate to current "q.digit" (v.digit in qgis)?
We find it far easier to use than the tcltk version.
It would be a pity to miss it in the future development.
pc
Jachym Cepicky ha scritto:
Jachym
grass-dev mailing list
grass-dev@grass.itc.it
Paolo Cavallini
email+jabber: cavallini@faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFFfRFg/NedwLUzIr4RAjB2AKCct1jenjpyw2omzZm1uXVk9mLlKQCfT5aB
IoIusSqWrdEGpV9qBhLulxA=
=Xfoq
-----END PGP SIGNATURE-----
hi,
Hash: SHA1
pc
QGIS is using different code for vector editing. Target of new v.digit &
v.edit is to get rid of dependancy on X-driver, rather then add new
features (in first step). As side effect, GRASS will get new tool for
non-interactive vector editing (v.edit). This could enable us, use GRASS
as background tool for web-based applications.
Jachym
> Hi,
> Jachym
Paolo Cavallini
www.faunalia.it
=Xfoq
Jachym Cepicky
OFFICE:
Zemedelska 3
613 00, Brno
Czech Republick
IMO all new GUI work should be done using wxPython.
Hamish
by all means reuse their design ideas and format if you like. but we do
ned our own digitizer unless we are deciding to make qgis our primary
GUI.
The r.in.poly format is very close the ascii vector format, so it
shouldn't be hard to build in a r.digit replacement as an export option.
Hamish
Hash: SHA1
I do not see the two project as so separated, and I think it is
unfortunate influential grass developers do (but of course, this is not
to blame anyone, just my point of view).
pc
Paolo Cavallini
www.faunalia.it
iD8DBQFFfUbi/NedwLUzIr4RAn/dAJwOexer2eSyheOl2ef6mjmEVnxjnQCeKhSn
R5PoWlzoe8nWQ1tmWYF8bxU=
=gm+8
Hash: SHA1
They are two seperate projects, with a bridge between the two built by Radim. I think we have had this discussion before and came to the conclusion that GRASS needs its own GUI independently from QGIS.
In my opinion QGIS is a great piece of software with much potential, but for my use I don't see any added value of using it instead of a much more lightweight internal GUI.
Moritz
