[GRASS-dev] v.digit: Could not set Tcl system encoding fixed
Roberto Flor and me have fixed the bug
"v.digit: Could not set Tcl system encoding"
http://intevation.de/rt/webrt?serial_num=4110
Please test. I'll backport it to 6.2.x then.
Note: For mysterious Tcl (?) reasons I cannot set iso8859-1 and iso8859-2
but utf-8, iso8859-15, iso2210-jp, koi8-r, euc-jp etc work.
Maybe my installation...
Markus Neteler wrote:
I confirm. Same happens on my instalation. tcl/tk 8.4.12, Ubuntu Dapper
32bit.
Maciek
Maciej Sieczka wrote on 02/07/2007 04:51 PM:
32bit.
So we are happy since most of the encodings now work.
> 32bit.
Not having ISO-8859-1 working is a pretty major issue.
Can you provide more details, preferably including a recipe to
reproduce the issue using either spearfish or a new location?
Glynn Clements wrote on 02/08/2007 12:41 PM:
32bit.
I am still not sure if it is a local problem or a general one or depends on the tcltk version.
Sure (eg Spearfish):
d.mon x0
v.digit -n newmap
# now go to "Settings" icon, "Table" tab, "Add column", add a column of your choice, "Create table"
# close the "Settings" window
# digitize a line
# enter a value into the attribute popup form
# "submit button" (default is utf-8 which seems to work)
# change the encoding, click "submit button" again and voila' the error appear in the terminal
>>> 32bit.
d.mon x0
v.digit -n newmap
# digitize a line
Okay.
I'm pretty sure that the problem is that lib/form/form.c doesn't call
Tcl_Main(), so the library path doesn't get set, so Tcl can't find its
.enc files.
Realistically, if you are trying to use Tcl/Tk and your program
*doesn't* look very much like tkAppInit.c, all bets are off.
Rather than trying to process the data from the form library in C,
form.c should just register the commands then do the rest in Tcl.
Glynn Clements wrote on 02/08/2007 11:38 PM:
32bit.
d.mon x0
v.digit -n newmap
# digitize a line
Okay.
.enc files.
Since I know nothing about tcl, I'll leave that to the experts. AFAIK form.c was
originally written by Radim.
> .enc files.
form.c was
The attached patch appears to work, insofar as v.digit appears to work
as before, minus the encoding errors. OTOH, I know next to nothing
about v.digit (or the vector stuff in general), so it would probably
be a good idea for it to be tested by someone who is familiar with
v.digit.
Essentially, the form utility (lib/form/form.c) has been rewritten as
a typical "extended wish", with the communication with the form
library being performed in Tcl.
(attachments)
form.diff (10.5 KB)
> > .enc files.
> form.c was
v.digit.
As I haven't had any response either way on this, I've committed the
changes.
