[latest 6.3 CVS]
v.digit is segfaulting for me on startup. It gets far enough that I need
to v.build the map to recover it.
G63> g.gisenv set="DEBUG=3"
G63> v.digit ant_coast_COPY
D2/3: node = 1491 nlines = 1
D2/3: node = 1492 nl = 1
D2/3: i = 0 line = 1493
D3/3: Vect_read_line()
D3/3: V2_read_line_nat(): line = 1493
D3/3: Vect__Read_line_nat: offset = 571401
D3/3: type = 2, do_cats = 0 dead = 0
D3/3: n_points = 10
D3/3: off = 571566
D2/3: node = 1492 nlines = 1
D3/3: Starting Tk_Main.
D3/3: v.digit Tcl_AppInit (...)
D3/3: Starting toolbox.tcl
D3/3: c_tool_centre()
D2/3: var_init
D2/3: Variable = 0x805d800
D2/3: cat_max_get() field = 1
Segmentation fault
same segfault using spearfish and copy of the roads vector.
DEGUG=1:
D1/1: dbln: 1 road_COPY cat $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
D1/1: field = 1 name = (null), table = road_COPY, key = cat, database = $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/, driver = dbf
D1/1: Dblinks read
D1/1: Vect_Rewind(): name = road_COPY
D1/1: dig_spidx_init()
D1/1: Map opened
Segmentation fault
thanks,
Hamish
