Michael Barton wrote:
OK. Looking through to the very bottom of the thread, there appears to be
some confusion about what is meant by GUI.
If v.digit is having a problem with a new vector when run from the toolbar
button in gism, it is one thing. This SHOULD be OK. I've checked the code
and it is written...
v.digit -n map=new_map
... as Glynn indicated. If this is where the problem lies, then, there is
some other kind of issue.
Contrary to the "resolved" status in the RT, the real bug remains.
v.digit is calling Tk_Main() as:
Tk_Main(argc, argv, Tcl_AppInit);
where argc/argv are those passed to main.
It shouldn't be doing this; it should be passing a dummy argv, e.g.
char *fake_argv[2];
fake_argv[0] = argv[0];
fake_argv[1] = NULL;
Tk_Main(1, fake_argv, Tcl_AppInit);
Changing the order of v.digit's arguments is a workaround, not a fix.
Glynn also noted, however, that in the auto-generated GUI dialogs, this is
being written as...
v.digit map=new_map -n
This causes a problem because the -n is misinterpreted by TclTk as a flag in
the TclTk command. So if the problem arises when v.digit is run from a menu
or the dialog is started from the CLI by simply typing v.digit, then THIS is
where the problem lies.
Generically, the GRASS flags should come before any other arguments it
seems. I don't know where this is coded, but Cedric should know.
The generate_tcl() function in lib/gis/parser.c writes out a list of
flags/options, with the flags last. gui.tcl passes the command-line
options to the module in their original order, i.e. with the flags
last.
This isn't a problem, as G_parser() doesn't care about the order. The
fact that putting the flags first happens to work around the bug in
v.digit is a coincidence, but not a particularly relevant one: v.digit
should still be fixed.
