[GRASS-dev] v.digit vs v.edit
does v.edit can do all things v.digit can do
what difference is between v.digit and v.edit
i had read the manual
if v.edit can do all things then what is the need for v.digit
both are used for digitisation right?
anyone please explain the differences between both module
ā€“
Rashad
2010/10/2 Mohammed Rashad <mohammedrashadkm@gmail.com>:
v.edit has been developed together with wxGUI digitizer, v.digit is quite older.
v.digit is interactive digitizer, v.edit is non-interactive.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
