[GRASS-dev] v.dissolve not working with string column
I’m trying to do a dissolve but keep getting an error saying that it only works with integer or string columns. But the column I’m using for the dissolve IS string.
GRASS 7.0.svn (Spain_utm_wgs84z30):~ > db.describe table=muro_temp
table:muro_temp
description:
insert:?
delete:?
ncols:4
nrows:177
column:cat
description:
type:INTEGER
len:20
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:Subsector
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:valley
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:sector
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
GRASS 7.0.svn (Spain_utm_wgs84z30):~ > v.dissolve input=muro_temp column=sector output=muro_sectors3
ERROR: Key column must be of type integer or string
Note above that the column “sector” IS text.
So what is wrong?
C. Michael Barton
Visiting Scientist, Integrated Science Program
National Center for Atmospheric Research &
University Consortium for Atmospheric Research
303-497-2889 (voice)
Arizona State University
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On 04/04/12 07:56, Michael Barton wrote:
I'm trying to do a dissolve but keep getting an error saying that it
only works with integer or string columns. But the column I'm using for
table:muro_temp
description:
insert:?
delete:?
ncols:4
nrows:177
column:cat
description:
type:INTEGER
len:20
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:Subsector
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:valley
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:sector
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
Note above that the column "sector" IS text.
So what is wrong?
v.dissolve checks for integer and character, but not for text.
Try this simple patch:
--- v.dissolve.py 2011-08-17 13:49:29.000000000 +0200
+++ v.dissolve.new.py 2012-04-04 08:04:00.000000000 +0200
@@ -66,7 +66,7 @@
          except KeyError:
              grass.fatal(_('Column <%s> not found') % column)
- if coltype['type'] not in ('INTEGER', 'CHARACTER'):
+ if coltype['type'] not in ('INTEGER', 'CHARACTER', 'TEXT'):
        grass.fatal(_("Key column must be of type integer or string"))
          f = grass.vector_layer_db(input, layer)
Moritz
On Wed, Apr 4, 2012 at 8:11 AM, Moritz Lennert
table:muro_temp
description:
insert:?
delete:?
ncols:4
nrows:177
column:cat
description:
type:INTEGER
len:20
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:Subsector
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:valley
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:sector
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
So what is wrong?
@@ -66,7 +66,7 @@
except KeyError:
    f = grass\.vector\_layer\_db\(input, layer\)
I have committed the patch and also added SMALLINT as valid integer in r51246.
Markus M
Thanks very much. For sqlite, there is no field type called "character". I tried changing the field type to varchar, but that didn't work either.
Michael
table:muro_temp
description:
insert:?
delete:?
ncols:4
nrows:177
column:cat
description:
type:INTEGER
len:20
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:Subsector
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:valley
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
column:sector
description:
type:TEXT
len:1000
scale:0
precision:0
default:
nullok:yes
select:?
update:?
So what is wrong?
@@ -66,7 +66,7 @@
        except KeyError:
Markus M
_____________________
C. Michael Barton
On Wed, Apr 4, 2012 at 4:58 PM, Michael Barton <Michael.Barton@asu.edu> wrote:
... but there is TEXT. Please post
v.info -c muro_temp
thanks
markusN
Right! That's the problem.
v.info -c muro_temp
Displaying column types/names for database connection of layer <1>:
INTEGER|cat
TEXT|Subsector
TEXT|valley
TEXT|sector
I want to dissolve on sector, but it complains that this is not a "string".
Michael
v.info -c muro_temp
thanks
markusN
C. Michael Barton
This is still happening in trunk r51246?
Markus M
