[GRASS-dev] v.external and postgis
I just try to link a postgis table with v.external but it return an error
GRASS 6.4.2svn (utm32n):~ > v.external dsn="PG:host=localhost
user=lucadelu dbname=osm" layer=trentino_point
out=trentino_point_grass
Building topology for vector map <trentino_point_grass>...
WARNING: Random read is not supported by OGR for this layer, cannot build
         support
can someonee test it? I just load an OSM file into postgis with
osm2pgsql [0] and after try to link a table in GRASS
[0] http://wiki.openstreetmap.org/wiki/Osm2pgsql
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
2012/2/13 Luca Delucchi <lucadeluge@gmail.com>:
support
the link is probably created (try `v.info`) but pseudo-topology is not
possible to build. In other words you can access features on level 1
(without topology). Has linked feature table defined primary key? BTW,
better to test `v.external` in G7 where many bugs when accessing OGR
data have been fixed.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
