On Wed, Aug 02, 2006 at 01:32:20PM +0200, Stephan Holl wrote:
Dear devs,
playing with sqlite as attribute-storage I found out, that the ID needs
to be an integer. I tried with this[1] sample
spearfish-sqlite-attributedb which has a 'numeric' type for ID.
v.db.connect does not complain as long as you do not use v.extract with
a where-statement to extract parts of your data.
The resulting dataset is broken afterwards.
To reproduce in spearfish60:
wget [1]
g.copy vect=soils@PERMANENT,soils_cp
v.db.connect -o map=soils_cp table=soils_legend
database=./soils_legend.db driver=sqlite key=id
v.db.select soils_cp|head
id|shortname|longname
0.000000|no data|no data
1.000000|AaB|Alice fine sandy loam, 0 to 6
Interestingly I get
v.db.select soils_cp|head -4
0|no data|no data
1|AaB|Alice fine sandy loam, 0 to 6
2|Ba|Barnum silt loam
I am using
rpm -qf /usr/lib64/libsqlite3.so.0
sqlite-3.3.4-6
but:
v.extract in=soils_cp out=soils_steep type=area where="longname LIKE
'%steep%'"
Load cats from the database (table = soils_legend, db
= ./soils_legend.db). 5 cats loaded from the database
Building topology ...
194 primitives registered
Building areas: 100%
39 areas built
16 isles built
Attaching islands: 100%
Attaching centroids: 100%
Topology was built.
Number of nodes : 171
Number of primitives: 194
Number of points : 0
Number of lines : 0
Number of boundaries: 164
Number of centroids : 30
Number of areas : 39
Number of isles : 16
Number of areas without centroid : 9
Writing attributes ...
Layer 1
ERROR: Column 'id' is not integer
ok, same problem here.
DEBUG=3 prints
D3/3: table: soils_cp
D3/3: select * from soils_legend where 0 = 1
D3/3: Escaped SQL: select * from soils_legend where 0 = 1
D3/3: describe_table()
D3/3: ncols = 3
D3/3: litetype = 2
D3/3: litetype = 3
D3/3: litetype = 3
D3/3: nkcols = 3
D3/3: litetype = 2
D2/3: col: id, nkcols 0, litetype : 2, sqltype 6
D3/3: litetype = 3
D2/3: col: shortname, nkcols 1, litetype : 3, sqltype 13
D3/3: litetype = 3
D2/3: col: longname, nkcols 2, litetype : 3, sqltype 13
D3/3: Select cursor opened
D3/3: ncols = 3
D3/3: id (DOUBLE PRECISION)
Analyzing it with db.describe:
db.describe soils_legend table=soils_legend database=./soils_legend.db
table:soils_legend
description:
insert:?
delete:?
ncols:3
column:id
description:
type:DOUBLE PRECISION
len:99999
scale:0
precision:0
default:
nullok:yes
select:?
update:?
The problem is that SQLite is type agnostic.
Datatypes In SQLite states:
"The key here is that the type is recommended, not required. Any column
can still store any type of data, in theory."
The only solution I see (while not knowing much about it!) is
to scan the entire cat (here 'ID') column if it contains only integer values,
if so, accept it as key column for v.extract or other commands,
otherwise refuse.
GRASS 6.1.cvs (spearfish60):
v.info soils_steep
ERROR: Cannot open old vector soils_steep@lausanne_db on level 2
I would suggest, that the driver does not create the dataset, if the
id-column is a non-integer.
In SQLite it's always non-integer/or non-integer is always possible.
Using a table with an int id-column works fine though.
I fear that it worked by chance.
Does anyone have a suggestion how to resolve this problem?
Not sure if the "Strict affinity mode" can help. To do a round()
cannot be the solution...
Best
Stephan
[1] http://mpa.itc.it/grasstutor/scripts/soils_legend.db
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
grass-dev mailing list
grass-dev@grass.itc.it
Markus Neteler <neteler itc it> http://mpa.itc.it/markus/
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
