[GRASS-dev] v.generalize smoothing loop support
hi all
i try make contours from DEM ASTER and i was successfull but contorus is ugly i try use v.generalze but this function cant change firt and las point , but some contrours is like loop (first and last point is the same) so after smoothing with sliging_averaging algo part around start point look_ahead wide was unchanged iwas so ugly , so i write patch which implementing loop line support , check if line is loop (start and endpoint is same ) and smooting correctly, is it usabel for others ?
black is war contours, blue is orig algo and red is with my patch
MSc. Miroslav Talasek
Developer, Team leader
Seznam.cz, a.s.
Prague
Czech Republic
tel.:+420 234 694 722
fax: +420 234 694 115
gsm: +420 608 934 724
jabber: mirecta@jabber.cz
work-email: miroslav.talasek@firma.seznam.cz
email: miroslav.talasek@seznam.cz
web:http://photo.talasek.sk
(attachments)
On Wed, Apr 17, 2013 at 10:54 AM, Miroslav Talasek
<miroslav.talasek@seznam.cz> wrote:
hi all
Yes, I think this is usuable for others. Do you mind sending the patch?
Markus M
Seznam.cz, a.s.
Prague
Czech Republic
grass-dev mailing list
grass-dev@lists.osgeo.org
is it ok ?
it add new parameter loop_support which would be 1 or 0 for loop line support in
hi all
Markus M
Seznam.cz, a.s.
Prague
Czech Republic
(attachments)
v.genealize.patch (6.82 KB)
it this path ok ?
do you use it ?
On Mon, Apr 22, 2013 at 10:40 AM, Miroslav Talasek
it this path ok ?
do you use it ?
I have added your loop support in r56252, with slight modifications:
loop support is activated with the -l flag.
Thanks for the contribution!
Markus M
On 04/17/2013 02:47 PM, Miroslav Talasek wrote:
is it ok ?
support in
hi all
Markus M
Seznam.cz, a.s.
Prague
Czech Republic
On Tue, May 14, 2013 at 4:46 PM, Markus Metz
it this path ok ?
do you use it ?
Now the smoothing algorithms boyle, chaiken, distance_weighting,
hermite, snakes also have loop support.
Markus M
is it ok ?
support in
hi all
Markus M
Seznam.cz, a.s.
Prague
Czech Republic
On Wed, May 15, 2013 at 4:26 PM, Markus Metz
it this path ok ?
do you use it ?
Excellent - I have added this to
http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Vectormodules
(@devs: please remember to add new cool stuff there :slight_smile:
thanks
markusN
it this path ok ?
do you use it ?
Loop support is now the default for all smoothing methods.
Updated accordingly.
Markus M
