I am trying to vector import from ascii files with 1000s of columns by
taking x=0 y=1 and z=$col
I must do it wrong:
v.in.ascii -z input=bior1.1_rcA2.csv output=bior1.1_rcA2_0000 separator=',' x=0 y=1 z=2 --o
ERROR: Column numbers must not be negative
Data files are like this:
(Lat, long, zval1, zval2, ...)
6.8000001907,55.1500015259,3.0500001907,4.3499999046,...
6.7000001907,55.1400015259,1.0200001907,7.3599999046,...
I must do it wrong:
> separator=',' x=0 y=1 z=2 --o ERROR: Column numbers must not be negative
Yann,
maybe "x=1, y=2, z=$col" where $col should be else than 1, 2
Can you share demo-data, a few lines? I can also try to give it a go.
