all excited to try out v.in.dxf but 3DFACE isn't implemented yet
I can convert the DXF to a polyline version, and import with the new -f
flag, but I need to run v.build before I can display it. After that I
can do g.region v=, display with d.vect, & display in NVIZ (3D vector).
Looking in v.info the x,y,z ranges are all 0,0.
Note the final x,y ranges are both negative. (?)
Also it exits with "No DXF layers found!" for the 3DFACE import.
This had me really puzzled as the layer does exist, it is just all
of unknown feature types. Could the error message be improved?
"... with data!"
"Layers found with no features"
"No features in layer"
Any plans for 3DFACE support? The wireframe is good stuff, but just a
skeleton.
Well, I think usual coordinates in DXF are not geographic coordinates, but it
depends on DXF files.
"... with data!"
v.in.dxf does not count layers it cannot import.
skeleton.
I haven't kept up with v.in.dxf since initially testing it and cheering its
incorporation into GRASS 6. But I'll be needing it soon and some of my
colleagues are using it quite a bit.
Is there a way to maintain a dxf entity attribute as a cat/attribute for
areas? The object it to avoid going through the complication of converting
lines to boundaries, adding centroids, adding cats, and linking cats with
attributes.
Michael
Arizona State University
Date: Tue, 6 Jun 2006 10:16:03 -0500
To: Hamish <hamish_nospam@yahoo.com>
Cc: grass5 <grass-dev@grass.itc.it>
Subject: [GRASS-dev] Re: v.in.dxf: support for 3DFACE?
Hamish,
On Wed, Jun 07, 2006 at 02:23:22AM +1200, Hamish wrote:
I fixed this bug.
"... with data!"
skeleton.
attributes.
I'll add the ENTITY column some time later.
Huidae Cho
Michael
> From: Huidae Cho <grass4u@gmail.com>
> Hamish,
>> Hi,
> I fixed this bug.
>> after import:
>> | N: 0.000 S: 0.000 |
>> | E: 0.000 W: 0.000 |
>> | B: 0.000 T: 0.000 |
>> after v.build:
>> | N: -4816.565 S: -5951.313 |
>> | E: -1943.884 W: -3092.723 |
>> | B: -11.644 T: 54.011 |
>> "... with data!"
>> skeleton.
>> http://www.autodesk.com/techpubs/autocad/acad2000/dxf/3dface_dxf_06.htm
>> http://freegis.org/cgi-bin/viewcvs.cgi/grass6/vector/v.in.dwg/entity.c?rev=HE
>> AD&content-type=text/vnd.viewcvs-markup
> Could you send me a sample DXF for 3DFACE and its screenshot?
> Thank you.
> Huidae Cho
Thanks. I'm passing this on to one of my colleagues who needs it right away.
Michael
Center for Social Dynamics and Complexity
Date: Tue, 6 Jun 2006 11:24:06 -0500
To: Michael Barton <michael.barton@asu.edu>
Cc: Hamish <hamish_nospam@yahoo.com>, grass5 <grass-dev@grass.itc.it>, Andrea
Moreno Martin <andrea.moreno@uv.es>
Subject: Re: [GRASS-dev] Re: v.in.dxf: support for 3DFACE?
attributes.
Huidae Cho
Michael
Hamish,
I fixed this bug.
it
"... with data!"
skeleton.
